When I’m off hunting and fishing at the camp, I usually bring clean water. But I like to have backup option. The thing is that « real » and safe filters are way too expensive to use merely as backups. That’s why I like to use chlorine dioxide (by Pristine), that give a better taste than Iodine. Also, the steripen (the Classic model) offers quick, easy and very safe way to treat water. But I was a little disapointed with its prefilter, that is 40 microns wide.
Here’s a quick way to transform an emergency straw type filter into a gravity flow drip system that can filter nasties down to 3 microns. Exit the tubing, valve, collapsible water container, glue, CamelBak, and ... technology.
Keep it simple and light!
Remove these ads by
Signing UpStep 1What you need
A Pristine Pioneer Emergency filter or Aquamira Frontier Filter. May not be the safest filters out there, but remember; I use this setup as a prefilter and a backup, before treating the water with UV or chemicals. You can buy one for about 15$. It can filter about 75 liters (enough for a fishing season!)
That’s it.
I have one of these (for hurricane season) and they work great, but use a good prefilter, to remove larger particles from the water, or you'll be cleaning it every 3 days.
I wouldn't know how to test the level of filtration but it was interesting.
We did it with some stream water when we filled up a pump style filter. We bandana screened the particulate out then the pump would do 3 microns. We chemed it after pumping just to comply with the camping regulations but it probably wasn't necessary.
RE: Turbid water: He recommended using a paper coffee filter. You could also stuff a bandana, strip of cotton cloth, or whatever in the funnel to reduce the solids before it gets to the filter.
