Introduction: Cheap and Easy Intercom
Picture of Cheap and Easy Intercom
In this instructable, I will teach you how to make a cheap and easy intercom with two(or more) walkie talkies.
Step 1:
Picture of
You will need two or more walkie talkies set to the same channel and some kind of case to hold it in(I used a couple of old modems).
Also you will need:
screwdriver/drill
pliers
wire strippers
Step 2:
Picture of
First, take apart both the modems and the walkie talkies.
Then discard the walkie talkie cases and the modem circuit boards
Step 3:
Picture of
Insert the walkie talkie circuit board into your case. I had to use a grinder to cut some pegs out so it would fit.
Step 4:
Picture of
Find out where you are going to put the speaker and drill holes there so you have something to talk into.
Step 5:
Picture of
You may need to drill out part of the back to reach the battery.
After that screw the case together and make sure everything is snuggly fit together.
then test and see if it works!
Step 6:
Picture of
My modem was kind of getting hot so I needed to cheek some wires.
hope it worked GREAT for you guys.
(P.S. this is my first instructable, sorry if it wasn't very good)
CaiTheGREAT (author)2017-03-31
Great idea!!! I am definitely doing this!!!! ;)
UtkarshJ1 (author)2015-12-26
i liked that tape....!!!! (bacon)??????
clarie91s (author)2014-04-13
So, it can be used without pressing any buttons? Like a walkie talkie needs to?
About This Instructable
9,170views
37favorites
License:
More by Macgeoffrey:How to make a sheep rainbow colorsRepeater/Forever CircuitHow to get a SECRET WORLD!!!!!! (Debug Mode)
Add instructable to:
