I have tried to use Konica Minolta Photo Quailty Matte Paper. Then design your own circuit and print it on the Matte Paper. Remember, before printing it. You need to mirror board. Otherwise, the circuit will be inversed.
Remove these ads by
Signing UpStep 1: Start to Iron It.
If some area cannot stick, it means your copper board is not clean enough. Remove the Paper and Use Acetone and Sand Paper to Clean it.
Visit Our Store »
Go Pro Today »
http://www.rapidonline.com/Tools-Equipment/Plain-Copper-Clad-Fibreglass-Circuit-Board-29478
http://www.mgchemicals.com/index.html
this is the actual company that i ordered from
http://www.alliedelec.com/Default.asp
I do not use inkjet glossy paper though but a page from a glossy magazine. costs nothing and the transfer comes out OK. Admittedly, there are a few dots of copper left here and there and the tracks have probably be exposed a bit too long, but nevertheles it is a very useable PCB.
From printing to etched was all in all 30 minutes max. Now there is the drilling to be done. I always find that a pain
There seems to be a method of printing straight from the printer to the board which looks even easier than this. The following page describes this method:
http://sites.google.com/site/calculatingrisk/Home/pcb-s-using-a-modified-bubblejet-printer
Has anybody done this with their printer and got it to work?
The question of "mirror or not" can't really be definitively answered unless all those other variables are accounted for, which would make for a loooong instructable.
In my etching experience, do a test print on regular paper, and do a thought experiment: imagine that regular paper as your transfer paper and work out what needs flipping for your own setup. Then print on the transfer paper.
CAUTION etchants creates harmful fumes, best done outside, using proper protections.
A suggestion about how to dispose of used Ferric Chloride etching solution. A current law prohibits disposal of those chemicals in the sewer.
Before you pour it in to the sink, pour it in a plastic tank (I used a sealable freezer bag) and drop in some scraps of old steel nails, screws, small, nuts, bolts, etc., and let it stay for a few days. It will turn the hazardous mix of copper chloride and Ferric Chloride (FeCl3) into copper powder (sludge) that settles on the bottom, and a non-etching and non-corrosive solution of FeCl2.
After separation of solution of FeCl2, mix it with solution of soda (Na2CO3 used as detergent) in a flat tray lined with plastic film. It will turn FeCl2 into Fe(CO3) (insoluble rusty mud) and NaCl (harmless cooking salt). After drying outdoor whole dry rusty powder could be wrapped in plastic film and disposed of in the normal trash container.
* Lazer transfers by heat.
* Ink dissolves in water, so when you attempt to etch it, the ink will dissolve it in water.
The toner side of the paper is the side of the paper that has the pattern printed on. Lots of videos on youtube that shows this procedure. GL
I've tried dozens of ways using standard A4 copy paper. I've tried ironing it, I've tried yelling at it, hitting it, whileas it only makes incomplete routes, requiring lots of rework with knife/rerouting.
The magazine paper idea worked out GREAT!! I've just finished my first etching proper PCB with all routes intact, no short circuits etc, even the tiniest ones going between IC pins seem fine! Can't wait to drill/solder this baby, but that'll have to wait till tomorrow.
Thanks.
I have used 'recycled' CD-label backing paper with success. Just remove all the remaining adhesive-backed labels and everything else from the waxy paper it was stuck to. Then use the waxy side for the transfer. The wax isn't enough to interfere with the circuit traces. Didn't seem to harm my old LJ2100 either.
I had ZERO success with ANY toner transfer methods until I tried these two things together:
1) After scrubbing the copper board, drop it into the etching solution for a few seconds. Remove and rinse. Be careful not to touch the copper after it is dipped/rinsed. It roughens up the surface and makes the toner stick much better. It also removes any deep-down dirt that the scrubbing missed.
2) When repairing traces with a "sharpie", roast the board on your iron for about 20-30 sec. to make sure the "sharpie" ink is completely dry, then etch.
I use a beat-up HP Laserjet 6L, press-n-peel blue with my iron on about 3/4 full heat and moderate pressure, and get great results. Your millage will vary. Experiment a bit. It is probably different with photo paper, but try the above tricks. Good luck!
Your instructable is nice anyway.
http://www.instructables.com/id/EN4JHYI8R7EYF7IYHZ was more complete though.
