Cheap and Easy Screwdriver Holder.
22,944
22
8
Posted in WorkshopOrganizing
Introduction: Cheap and Easy Screwdriver Holder.
Make a super cheap / Free Screwdriver holder! I was getting tired of having to root through a bin in order to find a screwdriver, so i made this free to me holder! In this instructable I will walk you through the process to make your own! Let's get started!
Step 1: Get Your Materials!
The only materials you really need for this instructable is a Pool noodle, and a way to mount it. However to get my finished results you'll need the following.
1. Pool Noodle
2. Flat Black (Krylon) Paint
3. Pins
4. Tape measure
5. Drill
6. Zap Straps
7. Knife
8. Screwdriver (Not in Picture)
Step 2: Cutting / Painting the Noodle
Determine where / how you want to mount the holder. I choose to Zap strap it above my repair station for easy access. If the noodle is the correct length already, then leave it as is. However if your need to shorten it just use a knife to cut to length. Once i had the noodle at the length i wanted, i hung it verticle so it could be painted with ease.
Step 3: Add Your Holes
Once you have let your holder dry for a couple hours, find your tape and pins. Lay the holder on a flat surface, and measure 1 1/2 inches from the end, and place your first pin. Continue placing pins every 1 1/2 inches until you reach the end. Next take a screwdriver and punch it through the holder where the first pin is. Keep pulling pins, and punching holes where the pins once marked until no pins remain.
Step 4: Mounting the Holder
The next step for me was to mount it to a shelf above my workstation. To do this all i did was drill three holes in the bottom of the shelf  big enough to fit my zap straps through. I then place the holder with the holes facing me, and secured it in place using the straps.
Step 5: Add the Screwdrivers
Next once everything is secure add all your screwdrivers! Finished / Completed! The great thing about painting the foam (used neon green) is after you poke the holes it's easy to see where they go back in.
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    8 Comments
    How do I modify this in order to see what tip of screwdriver I am pulling out ?
    you could just mark it with paint or tape his screwdrivers have the tip written on the end of the handle
    Gosh, just yesterday, I found a purple pool noodle down in the basement...and wondered what I could do with it. This is awesome!  I can see using this for jeweler's tools, and other besides screw drivers.  Awesome idea!
    I'm sorry to say, but this is incomprehensible! Please add an introduction, so I can understand what's going on (just this morning I was sorting incomplete screwdriver sets...).
    He poked holes in a pool noodle so that he could stick his screwdrivers in them.
    Thanks, I had no idea what a pool noodle is!
