3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap and Simple Tattoo Machine
Here is my first instructable... Sorry if my english is not very good because i´m from Argentina. And sorry if the quality of the photos is not good, that's because i have taken it with a phone...
I have done this TATTOO MACHINE a few weeks ago and works exellent, be careful to do every step well.
First, what is a tattoo machine?
A tattoo machine is a hand-held device generally used to create a tattoo, a permanent marking of the skin with indelible ink. Modern tattoo machines use electromagnetic coils to move an armature bar up and down, Connected to said armature bar is a barred needle grouping that pushes ink into the skin. Tattoo artists generally use the term "machine", or even "iron", to refer to their equipment. The word "gun" is often used but is looked down upon by professional artists. (From Wikipedia)
Reasons to do it :
.it's cheap
.it's fun to do it.
.it's esay to do
.you can do your own tatoo shop .... :D jejej
Step 1Project Overview
Project Overview
Introduction
Before getting starting on building a tattoo machine let me begin with a brief explanation on the format of this Instructable. The first step here will list out scope of the project. . Then the main Instructable begins... Steps 2 describe each component in the tattoo machine with some useful information . Step 3-8 describes the assembly process in a large mount of photos. Step 9 shows the finished tattoo machine and the 10 Step are tips.
Steps and Timeline:
1.00 hr - Preparing and gathering materials/tools
0.25 hr - Thinking through the design
0.10 hr - Preparing the pen
0.25 hr - Doubling the piece of metal
0.30 hr - Connecting the transformer to the motor
0.25 hr - Installing the needle into the pen
0.50 hr - Soldering motor
Total time: 1:51 min
Materials:
.1 Pen
.1 MOTOR of 6 volts or 12 volts (12 volts works better)
.1 Spoon or a small piece of metal
.1 Needle
.1 Transformer of 6 or 9 volts (not higher)
.1 Button 4 mm of diameter
. A little piece of wire
. A little stick or strong wire (it must enter in the pen)
Tools:
. A tin soldier
. Scissors
. Pliers
. Some tape
. Some glue
10 comments
Dec 19, 2011. 1:31 AMlemonie says:
Have you / do you intend to mutilate yourself with this?
L
Feb 23, 2012. 9:24 AMDNMEBOY says:
Getting a tattoo is not mutilation.....
But this home made tattoo gun is not the ideal way to do a tattoo. You'll only end up regretting it and having to get it covered with a bigger tattoo.
Feb 23, 2012. 12:51 PMlemonie says:
My OED defines "mutilate" as; remove limb, destroy use of the same, and imperfect by excision or some act of destruction.
That is what we both expect from a machine like this I think.
L
Feb 5, 2012. 7:20 AMxtian12 says:
did u use ure machine in skin?
Dec 26, 2011. 9:22 PMagis68 says:
i hope this is for fun not for using it
Dec 26, 2011. 4:43 AMcharles eletro 2012 says:
isn the paint
Dec 22, 2011. 10:05 PMyourmom003 says:
While this will work for tattooing, I find these types of devices to be better for engraving names/images/etc into metal or wood.
all you really need to do is replace the "needle" with a tougher and/or bigger tip
you can engrave your name into anything very nicely if you make your tool well enough.
Dec 18, 2011. 10:29 PMmikeasaurus says:
Interesting build, I'd like to see the results from the hands of a competent artist.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:electronicarts
