3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap and easy iPhone video camera mount
Step 3Bend the bracket and mount the case
Mark where you want to bend the bracket. You will want to make sure that the case has plenty of room to swivel from side to side. Test this a few times before you make the bend!
Once you bent it (I used a vice to get a clean bend), it is time to mount the case. Simply drill a hole in the case, push the screw through the case and washers in this order:
Bolt ==> case - washer - bracket - washer - nut
Tighten it down enough to make the bolt be somewhat flush with the inside of the case, but loose enough that it can still turn pretty easily. Don't get it too loose or it will not hold itself in position.
You probably want to put some tape over the bolt so it does not scratch up the back of your iPhone.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:jwilson27
I am very geeky. I love to do hardware stuff like electronics and robotics projects, as well as software (coding and such). I am a full-time net / sys admin, plus I balance being a manger in there s...
more »
