3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap and effective sanitizer
Step 3Doing the two step
Doing the two step
My process for cleaning is simple:
  1. Get spray bottles out from under sink (cool, dark place)
  2. Spray one bottle on all areas where it needs it
  3. Spray the other bottle
  4. Put the bottles back under the sink
  5. Wipe up with a sponge
And that's it. Lots of germs go away. Or, that's almost it. One last thing to be aware of before you try this. I'll even put it in bold.
WARNING:
White vinegar is an acid so do not spray it on anything for which this would be a problem so look it up first. For example, granite, marble, and grout need neutral cleaners so do NOT use this on them.
OK, that's it!
7 comments
May 28, 2010. 7:01 AMTreknology says:
How many problems have you had with the H202 corroding the ball valve or return spring in the trigger-spray head?
May 19, 2011. 3:35 AMNAZTNAZ says:
Unlike Bleach H2O2 won't corrode the ball in your spayer. I've used a spray top on a bottle for years on my pets (easier than dabbing with a swab) and have never had a problem with it.
May 27, 2010. 8:55 AMthirster42 says:
is there a reason why you wouldn't just mix the two in one bottle?
May 27, 2010. 9:58 AMchubenka says:
"never mix hydrogen peroxide and vinegar together in one container. The resulting chemical, peracetic acid, can harm you when mixed together this way if you accidentally create a strong concentration in this fashion."
http://www.michaelandjudystouffer.com/judy/articles/vinegar.htm
Not a good idea.
May 27, 2010. 11:40 AMthirster42 says:
so then what's to prevent the two mixing on the counter and making the acid?
May 27, 2010. 8:02 PMjohnny3h says:
They DO MIX AND react, BUT... the very small volume involved in a "mist" layer is a small enough total volume to be reasonably safe.
I'm not a chemist, but I suspect the result of combination of thin sprayed materials is the same as pouring liquids togethere, but because of the small amounts, the resultant amount of hazardous material is insignificant.
May 27, 2010. 1:39 PMchubenka says:
I think it has to do with the concentrations. John Q Public probably won't know the exact amount to put into one bottle so that it doesn't create the acid. Probably just spraying it on the counter is fine because it's being dispersed over a wide area.
May 27, 2010. 12:29 PMflamesami says:
the vinegar would screw up marble too... you might like to add that to your warning...;)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1411
Author:fungus amungus(my site)
I like to make things both useful and odd. The odd projects are usually more fun. I'm also the Content Manager here at Instructables. Follow @edabot for more
