Cheap and Reliable Remote Control Fan Regulator
Published
Introduction: Cheap and Reliable Remote Control Fan Regulator
Hi,
I am new to Instructables, I hope my mini project will be appreciated by many as this is economical and reliable and easy to built.
I am a beginner to this electronic field. I always like to do small electronic projects with less investment which relates to practical appliances.
This project provides a system that is easy to understand and also to operate, a system that would be cheap and affordable, reliable and easy to maintain the system of remote control and offers long durability. It adds more comfort to everyday living by removing the inconvenience of having to move around to operate a fan regulator. That's when remote controlled fan regulator came to my mind and here I go.....
Step 1: Lets Us See What All We Require!!
Components required:
1) IC NE555 - 2
2) IC CD4017 - 1
3) Voltage regulator IC (9V) 7809 - 1
4) IR Sensor TSOP 1738 - 1
5) Transistor BC148 - 5
6) Traic BT136 - 1
7) Zener diode (5.1V) - 1
8) Diode 1N4007 - 5
9) Diode 1N4148 - 5
10) Optoisolator MOC3021 - 1
11) Optocoupler MCT2E - 1
12) Transformer (12-0-12) - 1
13) LED (red) - 1
14) Power Cable (two pin) - 230V, 50Hz
15) Resistor
1K - 2
33K - 1
27K - 1
20K - 1
12K - 1
3.3K - 1
100K - 1
10K - 1
5.6K - 1
47 ohm - 3
4700 ohm - 1
47K - 1
330 ohm - 1
16) Capacitor
0.01uF - 3
10uF - 1
0.1uF - 2
4.7uF - 1
0.22uF - 1
470uF - 1
Step 2: Circuit Diagram
The circuit design looks like this.......
Step 3: Lets Make It
As shown in the circuit diagram, assemble the components according to the design and solder it to the board. Be careful while soldering to avoid short circuit between the components.
And finally the board looks like this.... I have also shown the remote circuit board snaps.
We can implement this circuit even using PCB to make circuit compact.
I did not include remote control circuit as you can use your own IR remote control circuitry. If you want to know you can contact me for the circuit.
Step 4: Video: Working of the Model
This video shows the working of fan which is controlled remotely from any corner of the room.
You can also use bulb in place of fan.
Step 5: Enjoy!!!!!!!!!!
I am done with the model. I hope you enjoyed the journey making " The less investment, more outcome" model.
please feel free to give the feedback. I will be glad for any improvements suggested!
Thank you guys for your precious time viewing my model.
please hit the vote button if you think its worth it.
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    5 Discussions
    what is the circuitry for transmitting the signal?
    How to control speed ?or is it just on off switching ?
    can we use any tv remote
