loading
Picture of Cheap, easy, low-waste trestle table plans
Build an attractive trestle table for about $100.00, in an hour and a half, using common materials, and minimum number of tools. It is suitable for dining or as a work table. It can can be set up or taken apart in a minute or two, using no tools, and stores compactly.
There are several holes to drill, but absolute precision isn't necessary, and a hand-held drill will work fine.
This version is 30" high, 36" wide, and 80" long. It seats 6 comfortably, and 8 in a pinch. It is also easily re-sized. If you would like material dimensions for other finished sizes, just leave a comment or PM me. Comments and ratings are more than welcome.
For a similar shelving unit, click here.
For a similar platform bed, click here.
As a professional carpenter, furniture maker, and designer/builder, I see a lot of home carpentry projects that are grossly overbuilt and over-engineered. One of the goals of this Instructable is to avoid the unnecessary overbuilding that I frequently see on this site, and that I see every day working in the residential construction industry. Many of the building methods we (in the US) use today are horribly wasteful despite the advances that have been made in materials science and structural engineering, because most people in the residential building industry, from architects and engineers to carpenters, are mired in tradition, doing things a certain way "because that is how it has always been done", rather than consulting the best available science, or even questioning their own assumptions about "the right way to do it". I don't intend to knock tradition, either. Many of the tricks, techniques, and tools that I use daily are definitely "old-school", but seem to have been forgotten.
1-40 of 79Next »
Just completed the table and it looks great. Needed for my home office. Used similar stains to yours minus the decorative cut out on the stretcher. My skills not ready for that. Still a great table. Thanks Aeray!
Pics attached including one of table in pieces minus tabletop:
aeray (author)  mhendrickson4 years ago
Looks great! Thanks for the pics.
bnolsen4 years ago
Would something like this be solid enough to use as a dining table? Using a solid core door is pretty awesome here!
aeray (author)  bnolsen4 years ago
We'll be using it as a worktable, but, yes, it is entirely appropriate, and sized to be, a dining table.
The solid core door is the easiest, most affordable tabletop I can think of.
CementTruck4 years ago
Beautiful! Looks reminiscent of Japanese/Frank LLoyd Wright inspired design. My all time favorite.
What did you use for the stain on the trestles? I'm building a dining room table and matching buffet and I want to have a dark brown stain, and I want barely any grain showing as I am using cheap lumber.
aeray (author)  CementTruck4 years ago
This is cheap lumber as well. White Fir. I used Minwax Ebony for the trestles, and Minwax English Chestnut for the stretcher.
Thelowlow 12 days ago
I would like to make the same table with a door slab that is 32" wide, same length. Can you please provide measurements?
I guess everything would be the same except the dowel holes on the table right?
aeray (author)  Thelowlow 11 days ago
Correct.
BartholomewH2 months ago
Looks great!
DixieG12 months ago
This is great! Have you made plans for a table that could fit 8-10, and up to 12?
aeray (author)  DixieG12 months ago
We've had 10 at this one before, but it is a little tight. The plans for a bigger one are the same, just use a longer door, and lengthen the stretcher. For example: order an 8' tall door slab. This is 16" longer than the one in this Instructable. Make the stretcher 16" longer as well. Everything else is the same.
AudreyCMcNabb5 months ago
Can you get these doors for the top in 8ft? I would need about an 8ft long table. Would I just extend the center piece of wood another 1.5 ft? Or do other changes need to be made to extend the length?
aeray (author)  AudreyCMcNabb5 months ago
Yep. Just ask your lumberyard. The only change is making the spreader 1' 4" longer (16").
EB-DIY made it!1 year ago
Really liked the simplicity of the design - had been looking for a trestle plan to use for the blue pine slab top I was making... works for me - and the wife likes it!
Thanks for the detailed description -
aeray (author)  EB-DIY9 months ago
de nada. Thanks for the photos.
lisabarnes9 months ago
can you give me the material dimensions for a 36 wide and 72 long table? thanks!
aeray (author)  lisabarnes9 months ago
Almost everything is the same: just order a 72" door, and subtract 6" from the stretcher length. That's it!
newmey made it!1 year ago
Finished my smaller version this past weekend. I found a 32" solid core door for $8 that was slightly blemished. I ended up having to cut it down narrower and banding the edges with some pine to make it work in the narrow breakfast nook. The top is 30" X 53".
aeray (author)  newmey1 year ago
Looks good. Thanks for the photo. Did you make the benches, too?
newmey aeray1 year ago
No, they were originally booths in a now closed pub.
We love the look of the table. My wife has actually agreed to giving me uninterrupted time in my workshop to build it. You mentioned that you could send adjusted measurements. I am interested in smaller table. Could it be modified for a 36" wide x 48" long table? Could two 12" drop leaf sides be added to the 48" length to make it 72"? What would be the changes for a 36" x 48" table?
Thanks in advance, Scott
aeray (author)  sjeffries661 year ago
The proportions start to look weird when it gets that small, but there are some options. As for the drop leaf, that is a whole 'nother beast. The simplest, cheapest, best looking option may be to simply have two tabletops: one at 48" and one at 72". Door slabs are pretty cheap, and changing it would be a simple as lifting one off and setting the other on. Send me a PM with your email address and I can send you a few dimensioned PDF drawings to look at.
I am going to substitute the door top with some old oak church pews that I resurfaced and joined. I look forward to your guidance on dimensions for smaller top.
Thanks again,
Scott
sjeffries66@hotmail.com
califazen made it!1 year ago
I had a little trouble (measure with care) but because this is a very forgiving design, an adjustment (and an invisible shim) and its just fine. I put it to work right after the third coat of clear-coat was dry, to support my old Singer 301A. Next, a couple benches for it. I did the bed, earlier, and it was a snap. Thanks for these thoughtful plans.
aeray (author)  califazen1 year ago
Thanks for the photo!
mbmoore5031 year ago
Beautiful table! I want to scale it down to 30"-32" wide and 6' long. Can you advise me? Thanks
aeray (author)  mbmoore5031 year ago
Reduce the length of the four horizontal trestle pieces by whatever the difference between the existing tabletop width is and the width you decide on i.e. 30" width = 36" original - 30" for yours = subtract 6" from the given lengths of the trestle pieces. Similarly, for a 6' long table, subtract 8" from the stretcher length.
Order a door of the corresponding size, for this example, a "2-6, 6-0" door.
Dolfan131 year ago
I love this design, but was wondering your thoughts on using cedar planks for the table top. I have a cedar TNG ceiling on my back porch and was looking to match the ceiling. Any advice would be very much appreciated.
aeray (author)  Dolfan131 year ago
Google "breadboard tabletop" for an idea of the proper way to do it. Remember, though, that cedar is very very soft. A better option would be to find a  door
like this
but in wood, not fiberglass.
tallnproud1 year ago
I just finished (well, almost finished... needs a couple coats of polycrylic) putting together the table, and I am very happy with the results. My wife wanted wider than 36" for the tabletop, so I used a 4' x 6' slab of 3/4" birch plywood with a support frame on the underside (see picture). Per your advice, I also drove in four screws to increase the stability and security. Overall, it was more difficult than assembling the bed frames (of which I've now made three), but it was definitely manageable. Your instructions are easy to follow, and the pictures always cleared up any questions that I had.
Thanks for posting these, and I can't wait to see if/when you post the instructions for the chair.
aeray (author)  tallnproud1 year ago
​thanks for the photos, it looks good. It is definitely a bit more advanced than the bed or the bookshelves, but I tried to keep it manageable. If the plywood top gives you any trouble, you can get a door slab in that size, but it will be more expensive than what I listed. But, depending on climate and specific type of plywood, you may not have any problems. The additional screws will also help with that.
I'm building this table for use in my dining room, but I concerns about the stability. I have a two and four year old who will likely run around, hang on, bump into, and (in many other manners) abuse the table. I'm worried that since it's only kept in place with the unglued dowels, that they might loose the table top from the legs and hurt themselves or others. Can you speak to its sturdiness and/or offer advice to make it more stable. I don't mind losing the ability to easily disassemble in favor of greater stability.
It should be fine. Ours has been abused by a five-year old, and takes two adults to lift the top off. A single 2-1/2" screw up through each of the upper crosspieces into the underside of the tabletop should provide a little reassurance though.
finnigan161 year ago
This is a beautiful job, and very perspicuous instructions! Do you have any plans of adding on instructable for chairs that could match?
aeray (author)  finnigan161 year ago
Excellent vocabulary. I have thought about chairs for it; chairs are kind of the Holy Grail of furniture making. It is also surprisingly difficult to design and build one that is comfortable and durable. Add in my goals for this series (cheap, low-waste, easy, common materials, minimal tools and skills required) and the task becomes fairly daunting. I do have a few ideas, though, and hundreds of sketches...
vjdoro1 year ago
I love the look of this table and would like to someday make one to replace what I have, but for now I need to make a Physical Therapy exam table for my daughter who is in PT school and needs an appropriate height surface for practice. I like the trestle idea for storage of the table when not in use. The top surface I was thinking foam padding and covered with vinyl rather than the solid core door. My question is what is the load bearing ability of this trestle table, and how stable is it from side to side. I need to make a table that is stable for offloading of the practice victim, namely me, and other assorted family members. I did consider the platform bed design. I have completed 2 of those beds a queen and a twin. the twin size which is about the size needed for the exam table, wasn't as stable when a my son was sitting on the edge, (he could if he tried make the bed start to tip.) Also I can't think of how to make it storage friendly. Any ideas that you'd be willing to share? Thanks ahead of time, still love my platform bed, still very sturdy and love the storage underneath, thanks for your designs.
aeray (author)  vjdoro1 year ago
I don't think my design would be appropriate for that use, in part because the top isn't secured. I'd be more inclined to try a solid core door (with padding, etc.) on 1" or 1-1/4" pipe legs, attached using floor flanges like these: http://t.homedepot.com/p/1-in-Black-Malleable-Iron-Threaded-Floor-Flange-521-605HN/100179931
vjdoro aeray1 year ago
Ok thanks for the advise, I'll look into the floor flanges, thanks for the reply.
saidig2 years ago
This looks great!!! I did your bookcase and so many people love it. I keep showing them your instructions :)
I am looking to make a stand up desk. I work from home so the desk needs to be sturdy enough to carry both of my iMacs which together are 51lbs and little stuff here and there. Would this table be sturdy enough?
Also taken you up in your offer and if you think this would be a sturdy enough desk, what would be the material dimensions for a desk 39" high, 65" long and 30" wide (if leaving it 36" wide makes it easier I don't mind, I know at Home Depot you can special order any size door).
Thanks!
1-40 of 79Next »
