Cheap iphone macro lens for barcode scanning
A glaring problem with the iPhone's camera is its inability to focus closer than ~1 foot away. Some aftermarket solutions help fix this problem such as the iClarifi by Griffin Technology. This case for the iPhone 3G allows you to slide a little macro lens over the camera to take closeup pictures, and is also handy for scanning barcodes for use with apps like snapr.net.
I've got a 2G iPhone and a limited budget and wanted in on this barcode-scanning fun as well. I googled some things and was inspired by this, but it wasn't quite what I wanted. I finally came up with the following cheap (free) solution.
What you need:
-a disposable camera. You can get these from most any photo counter, for processing they just crack the film out and will recycle the rest. They'll usually give you a handful of cameras for free if you tell them you're doing a project.
-a flathead screwdriver or something else to pry the camera case open.
-a flexible iPhone case. Not necessary, but you've gotta mount the lens somehow. I got a case for $5 at 5 Below.
Step 1Assess the salvaged disposable camera
Salvaged cameras will be in various states of disassembly, but almost any camera will do. The Kodaks seem to be more plentiful and they have more plastic that we can use for mounting, as you'll see later. All we need from the camera is the viewfinder lens that is closest to your eye when you're taking a picture. The camera contains other lenses, including a slight telephoto lens, but I've found this one is the best for barcode scanning purposes.
WARNING!!! These cameras have a large capacitor for the flash which can give you a very damaging shock if you touch it. Stay away from the circuit board or you may get injured. The people at the photo place will probably warn you about this as well. You should probably wear safety goggles for this project.
Also, do NOT press the "flash" button before you start to take apart the camera, or you can be sure that you've made the project a lot more dangerous than it needs to be.
35 comments
Nov 8, 2011. 10:37 PMappsman says:
For the iPhone 4 or 4S, 3D print a cute macro lens. Shown here:
http://www.instructables.com/id/Make-an-iPhone-4-or-4S-slide-on-macro-lens/
Aug 4, 2011. 7:54 PMgeraldkrug says:
This is a great thing you made. Are you still testing out barcode apps with it?
Aug 25, 2011. 9:38 PMthedoc67 says:
Wow awesome project!!!
TheDoc67
www.freshtaste.co
Sep 8, 2009. 4:53 PMjam BD says:
Very neat .... =D
Aug 29, 2009. 5:45 AMmetaldazza says:
This is cool. I removed the same lens to use on a mac book pro to get it to work with Beep My Stuff. I blogged it here but it's basically the same as what you've done. Thanks for posting this.
Jan 7, 2009. 7:13 PMKryptonite says:
This is cool, but next time, why not just use a non-flash-disposable-camera instead? Probably safer, I've seen what happens when you play around with these. (The pliers used to discharge the capacitor is no longer alive, poor Bob, may he rest in piece(s))
Jan 7, 2009. 8:29 PMzwild1 says:
You're right. But it's pretty hard too really hurt yourself with one of those. Sure it might give you a little scare, but fatality i think not.
Jan 8, 2009. 1:54 AMKryptonite says:
Yeah, fatality's out, but it does hurt. :S It'd probably just be easier to use non-flash though, so if you've got an option... well, you get the point.
Apr 1, 2009. 8:02 PMKryptonite says:
I hate the idea of tasers, and to an extent stunguns, I've seen one in use and it looks like those medieval tortcher chambers. Painful. Sometimes it can rip the muscle off the bone if they wind the voltage up enough. Most of the ones I acquired were none flash, oh well I guess it depends on your camera store. i busted a perfectly nice set of pliers ($2) when short circuitting one of these. Sad face.
Jan 7, 2009. 7:47 PMIzokay says:
Plus cheaper
How's it cheaper?
Jan 8, 2009. 3:11 PMvakama380 says:
But your be getting the used camera for free see?
Jan 8, 2009. 2:05 PMIzokay says:
Wouldn't non-flash be cheaper?
Jan 8, 2009. 8:15 PMKryptonite says:
You don't buy it, if you plan to get a disposable camera and not use the film, just go to a camera store and ask for a used disposable camera. Just say that it's for a project and they'll happily give you as many as you want. They recycle them any way.
Jan 6, 2009. 5:54 PMfynflood says:
Jan 14, 2009. 1:15 PMbarcodeguy1 says:
Literally too many moving parts. Why is this always so complicated. (rant over). I wish someone would invest in making the technology so you can read the UPC, EAN and other codes that are already on products, inventory and documents, and have the program decode the characters and send them to the application you want - like your contact manager or notes application. Then, we wouldn't be captive to a particular code, company or equipment mix, and could even print our own barcodes, like using a code 39 font and scanning them into the application of our choice.
Jan 7, 2009. 7:32 AMarashiodori says:
I might as well just get a much better Nokia or any other camera phone with proper focussing...
Jan 7, 2009. 4:32 PMcam54321 says:
If you are going to buy a cell phone based on its camera, buy a camera...
Mar 31, 2009. 6:04 PM142400 says:
Mar 31, 2009. 6:29 PMcam54321 says:
Yes you could, but then you have a case which isn't necessarily a good case. All so you can focus up close, it still doesn't make the iPhone camera a truly good camera. Also seeing as this is a site for DIY, showing what alternatives you could buy isn't really very helpful.
Jan 8, 2009. 2:07 AMarashiodori says:
And if I don't want the additional baggage? Get a better all-in-one device...
Mar 31, 2009. 10:53 PMarashiodori says:
That, and I cannot share it over Bluetooth...
Jan 8, 2009. 8:08 PMadamthiede says:
works with the 3G? I don't have an iphone, but im just wondering...
Jan 8, 2009. 9:20 AMXaledo says:
Nice! I'll try this. I actually have the same case (from Apple's own website!) for a lot more money, and it broke very quickly. I need to get a new one, desperately.
Jan 7, 2009. 9:02 PMbaxterdog says:
This is an awesome idea. I searched and searched for one of these cases that would fit my iphone. I don't have the 3G. This is incredibly useful for ANY closeup. Kudos. Perhaps just a cheap plastic magnifier might work as well, we're just talking lenses here.
Jan 6, 2009. 10:23 PMchrisayad says:
AHAHA yeah dude stop making me get an iphone!!!
Jan 6, 2009. 8:27 PMalex-sharetskiy says:
Cool! now i need to get myself an iPhone..
Jan 6, 2009. 1:15 PM=SMART= says:
This is really cool! a great, cheap soloution to an awfull design flaw !
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:ch0rtle
