3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap light box
Cheap light box
The goal was to make a light box for my students to use that didn't cost me an arm and a leg. Went to the second-hand store and found a florescent light... ($4.99 with 50% off) then noticed a suitcase/briefcase ($3.99 with 50% off). I got them both and started thinking of ways to put them together.
Step 1Painting & light
Painting & light
Paint the inside of the suitcase white. Better to reflect the light out. Make it brighter?
Take apart the florescent light. You only need the power supply, light, light socket part and switch.
Then I positioned the light so it was in the middle of the case; using hot glue and rivets I secured the light in place.
Note: Got new two setting hot glue gun. Two setting: Low = normal glue gun, High = burn yourself, stays runny way longer and oh ya burn yourself.
55 comments
1-40 of 55next »
Aug 25, 2010. 9:54 PMNastan says:
I still can't believe no one has mentioned that this would work for a pulp fiction briefcase. I am going to try and do this with a cheap RC battery or something.
Mar 26, 2011. 10:30 AMphilmckn says:
Looks like most of the light is concentrated in the upper right quadrant of the box. Has this been a problem when using the box or does the picture exaggerate the effect?
Nov 14, 2011. 3:25 AMunreal_ed says:
Is there any chance you would consider making one to be sold, and if so, for how much?
Mar 16, 2012. 4:30 AMabstracted says:
luv the idea of...it can be closed up n put away, way more storable than, say some of the wooden boxes ive made. i have a round florescent bulb n the balast. i got it frm a light up sign, should work awesomely.
Nov 10, 2011. 10:41 AMrmestler says:
Genius! I can't believe I didn't think of this idea! My grandmother has tons of these old briefcases. I'm about to walk over there right now and grab one. Thank you for taking the time to share your idea! <3
Feb 26, 2011. 4:56 PMstncilr says:
Awesome idea, i already have a suitcase and am starting to plan my new project!
Sep 29, 2010. 1:37 AMbryandhispup says:
love! My school has several BROKEN light boxes, and due to budget restrains they are not fixing them yet. This is a GREAT solution to my Light Box Needs!!! Thanks!
Jul 11, 2010. 12:05 AMchaseracer17 says:
This also works for stenciling?
May 14, 2009. 7:48 PMTakelababy says:
If tracing something we used to just tape it to a sunny window.
Jul 28, 2009. 11:51 AMimagine30 says:
I really want to make one of these, it seems like it would work well for traditional animation. Just wondering what was the total price for everything you bought?
Jun 3, 2009. 5:06 AMarsenaltoyz says:
this was and is a perfect idea for an artist who like traveling u might have a little issue with security if u r riding in a plane but other than that is perfect for the ever traveling artist.
May 25, 2009. 9:23 PMstatic says:
Nice project/instructable. A light box is one of those projects that's perpetually in the back of my mind. I had always figured I design it around a stock size of tempered glass. Safe, and some what resistant to scratching from the tools usually used with a light box.
May 25, 2009. 7:36 AMKryptoTSD says:
Hi! KryptoTSD here... I'm another knows nothing about electronics... I would like some dumbed down instructions about fabricating with LEDs... I like the looks of this project... I bet it would work swell with LEDs, too... KryptoTSD ktsd
May 21, 2009. 11:52 PMmario59 says:
Oh, I love the way you did it! I love EASY&USEFUL way to do things! And you did it! CONGRATULATIONS!
May 14, 2009. 5:56 PMlordofthedonuts says:
I did almost the same thing but used cheap white LEDs from china. it took the whole night soldering every 100 of them on the perfboard but it was worth it. it can run of a battery so you can draw everywhere you go.
May 21, 2009. 7:44 PMSquash says:
I'd be interested in an instructable of for that. I'm trying to find someone to help me with detailed instructions on wiring LEDs for a painting project but so far no one wants to "dumb-down" the instructions for someone who knows nothing about electronics. :-(
May 21, 2009. 1:31 PMhodderbk says:
Do you think this would work for small-scale screen printing? The plastic cover would have to be clear instead of milky. I know this is a rather specialized question, but I'm looking to start screen printing at home, and I don't have room for a giant light table.
May 21, 2009. 11:37 AMjphphotography says:
This is genious, too bad I found it too late. I built a simple wood box instead but the rest of the principles are the same. I've still got an extra flourescent bulb & fixture and some white lexan left, maybe I'll give my other one away and build rev 2.0 ;) Thanks for sharing this
May 21, 2009. 10:24 AMpauldaryl says:
RE: 'Milky Plastic' aka: Acrylic,Plexiglas, or Lucite; Acrylic being the generic term. The translucent white comes in two flavours: 1.) 7328 aka: Sign white; what they use for illuminated sign on store fronts. Lets enough light through to illuminate the surface well,very diffused, also masks the light source well. 2.) 2447 Very Translucent; more akin to rice paper. Light source may be more evident. Both can be found at Home Depot or other Hardware Stores. Avoid the light Lens material; it's styrene, and very flimsy. Yes; keeping the masking on while working Acrylic is a good idea; Its pretty durable, but can scratch easily.
May 21, 2009. 8:31 AMneedexercise3 says:
Great, simple project! I always make stuff too complicated. Giving in to that urge: ;-) It looks much brighter in the middle. What are some simple ways to make the illumination more even? Angled white cardboard(?) reflectors in the corners, to reflect light up toward the screen. I'd use a low-profile fluorescent, spacers, or a deeper suitcase to increase the distance from bulbs to screen. Try a vertical reflector between the bulbs (straight? 'V'? gull-wing?), so instead of both bulbs lighting up the center, the reflector would send some light off to the sides.
May 21, 2009. 8:19 AMsassycrafter says:
Love it! This would have been a great project to submit to the ReadyMade MacGyver challenge for old luggage: http://readymade.com/projects/article/luggage_challenge_winner.
May 21, 2009. 7:26 AMCreaturiste says:
Wonderfully practical, and stylish! Thanks for taking the time to write this!
May 21, 2009. 4:21 AMddsouza says:
Nice Instructable. I had made a similar unit for my kids using and old Canon scanner that I found at a Thrift store and IKEA LED light strips. The fluorescent however would have a higher output.
May 18, 2009. 11:37 AMwichypoo says:
FYI I need one of these, quilters use light boxes to transfer patterns etc. Using a window really tires your arms out. I know. Could you use a heat resistant glass cutting board ? Line the box (suitcase) with heat resistant silver fabric?? just wondering.
May 17, 2009. 11:00 PMLance Mt. says:
Hmmmm you know.. I might just do this
May 14, 2009. 3:38 PMwillymakesstuff says:
why would u need a light box just wondering
May 18, 2009. 12:30 AMdisturbed_1 says:
Also for screen printing... because the sun makes a crappy light source D:
But this is a great project... Faving =3
May 16, 2009. 5:25 PMwillymakesstuff says:
oo for like tracing yeah i forgot bout that
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:bigtreehouse
