Remove these ads by
Signing UpStep 1Materials
- Frame: This can really be anything. Embroidery hoops, some stiff cardboard, or a bucket with a hole in it. I found a picture frame on clearance for $.75! It is plastic, so washing the ink doesn't do anything real bad to it, and it may hold up longer then cardboard. ($.75)
- The Screen: The most important part. Anything that the ink you are trying to use will ooze through. I used a friends worn out nylon stockings. When it gets stretched a bit it all works out. (Free!)
- The Ink: I had some Fabric Screen Printing Ink left over from another shirt project, so I used it. Some kind of latex paint or something similar will probably work too. ($7)
- The Blocker: This is what you put on the screen, to block the parts you don't want ink to go through. Most screen printing uses a photo transfer technique which uses some chemicals, and light and more things to buy specialized. Using the paint I had on hand saved me some money here. I used some white acrylic paint I had on hand. Elmers glue, wood glue, maybe pieces of paper if you work it right will do the job. ($2 (I think) for a small amount)
For years, I've used an ordinary office / home stapler to attach the screen material to a frame. Those staples will hold the screen, but are not as thick or large.
NOTE: It is important when using staples of any kind to attach the screen to make sure:
1. The staples are fully seated / bedded into the frame so that nothing is sticking up to "snag" on whatever material you're printing on.
2. Even after making sure the staples are flush with the surface, I alway cover the staples, AND the screen material edge with masking tape to guarantee no damage will occur to the surface of what I'm printing on.
I've also found that using modge podge works really well!
