3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap pocket sized iPhone/iPod Touch stylus
The first day I got my iPod Touch, I noticed that it would only respond to bare skin. I thought that was pretty cool, but soon after I wanted to be able to use a stylus. I found out that it takes something that generates energy to use the iPhone touch screen. You could just use tinfoil, becuase your energy travels through it to the device, but I didn't want to scratch the screen of my iPod touch. After some more research, I decided to create my own stylus. In this instructable, you will learn how to make a VERY CHEAP, VERY EFFECTIVE iPhone/iPod touch stylus.
(I beleive instructables user flyingpotato has made an iphone stylus, and i give him credit for that, but mine has a q-tip in it so it doesn't scratch the screen)
Step 1Materials
Materials
All you will need for this instructable is a q-tip,
a 2.5 x 7 inch peice of tinfoil, and a drop of water.
27 comments
Apr 28, 2012. 8:51 PMphreddd says:
Spit actually works with this... who knew?
Apr 7, 2012. 4:41 PMTheRealPeregrinus says:
Elegant solution. Works great. Going to use this until I find a soft conductive material I won't have to wet.
Dec 29, 2011. 5:44 PMNE patsrock says:
very cool dude
Apr 12, 2010. 10:05 AMjkolins says:
what "erks" me is the terminology. Seems as though INSTRUCTABLE can get the NYT attention. I can't. TOUCH screen on the I-Pad or DROID phone is wrong!!!!! it is a capacity screen. If you are in a cold climite and want to access your gaget, you are screwed, without taking off your gloves. NOT SO with a GARMIN GPS unit...thank G--. The Garmin  is a true TOUCH SCREEN.
 CAN YOU GET THAT MESSAGE OUT TO THE WORLD???
thanks for listening,
Jerry
Jun 14, 2011. 12:20 PMGlaceon says:
Isn't it like the Nintendo DS, in the sense that it's pressure-sensitive? And you don't have to yell. We can all hear (well, SEE) you...
Oct 23, 2011. 8:49 PMCaleb Nehrbass says:
No, it isn't the same. You can put ALL your fingers on the screen at the same time, and it still registers them. The DS, DS lite, DSi, and 3DS all use a different system. If you go to pictochat or something, then put 2 things on the screen, the line that is being drawn will be in the middle.
Jul 31, 2011. 8:44 PMkdiehl says:
This is great. I made one and it works well on my Tablet. I also used electrical tape to wrap around the parts that don't need to be touching your fingers. Makes it sturdy and look cool.
Jul 31, 2011. 9:28 AMggg shock says:
well i have a styus but it might work take every thing out of a pen so u have the body of the pen the u stuff the tinfoil in the carcous of the penand some tin foil out side then tape it
Jul 31, 2011. 8:28 AMggg shock says:
working great abslutly love it do you have to wet every time you use it
Sep 26, 2010. 10:34 PMwavemaster447 says:
Worked like a charm! If you're interested in a colored stylus, candy wrappers or gum foil's work also.
Sep 26, 2010. 10:33 PMwavemaster447 says:
Sep 19, 2010. 3:28 AMmichaelgohjs says:
i tried it and it works but it dries kinda fast
here is my stylus
http://www.instructables.com/id/CHEAP-FAST-AND-STYLISH-IPAD-STYLUS-cost-me-0-aga/
it uses aluminum foil and an antenna as the core conductor
it works for laptop touchpads too
Aug 6, 2010. 2:46 AMsarahju says:
i tried it and it didn´t work :-(
Apr 25, 2010. 2:26 PMgoddessofchaos says:
 Another 2¢ here after I tried the pencil.  It didn't work.  Then I realized your fingers have to be touching the foil so if you have the foil sticking out far enough that your fingers touch it it should be okay.
Apr 25, 2010. 1:57 PMgoddessofchaos says:
This was great!  I wrapped a bit of copper foil tape (used for stained glass) and didn't even have to come all that close to the tip for it to work a treat.  Am now going to put the cotton  covering over the end of a mechanical pencil with a clip so I can hook it to the cord I put on my iTouch.  I like to read books on it and was afraid I might drop it on a plane if I fell asleep.  Instructables is the greatest!
Jun 23, 2009. 7:16 PMpoop11346 says:
The screen of the iphone can not be scratched
Apr 15, 2010. 10:37 AMakr34 says:
It's definitely scratch-able.
Jun 25, 2009. 2:28 PMgeekazoid says:
phf! D'u have an iphone? Unless the screens oof the ipod touch and the iphone are different (i have a touch) yes, they can be scratched. PS: then why would they even make screen protecters if it were unscratchable. PPS: good 'ible.
Feb 21, 2010. 4:44 AMDante-sama says:
 Making screen protectors means that they can get more money easily.. :P
Jun 24, 2009. 4:50 AMinstructors says:
Trust me in that the screen can be scratched. The screen is scratch RESISTANT and NOT scratch proof.
Apr 7, 2010. 7:51 PMAtlas22 says:
Trust me on the screen, it isn't scratch proof (sadly, i tested that...)
Mar 13, 2010. 12:03 PMsoupstreet says:
It's not working ! What should i do ? :|
Mar 29, 2010. 3:03 AMTricDoc says:
Mine works. wrap it to very nearly the edge, lick your finger and rub it onto  the end.
Jul 18, 2009. 11:59 AMnepheron says:
This sounds pretty unusual, but i have been able to use jade with touch screens. The strange thing is, it only works if you hold certain axis... maybie jade is magical, huh?
Jun 23, 2009. 10:26 AMBerserk87 says:
(removed by author or community request)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:Halotriple3
