3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheap, quick and easy to do, Moleskine-like notebook with Clairefontaine paper
Step 2Cut the paper sheets to the right size
cut the paper sheets to the right size
the outside sheet should be at least 3cm (about 1") larger and higher than the notebook itself (open fully the notebook to take the dimensions). this way it should have a 1.5cm (about 1/2") margin on each four sides of the fully open notebook.
the inside sheets should be cut about 2mm less than the height of the notebook. It should be wider than the width of the closed book. If you want to have the inside sheet on the four pages of the beginning and the end of the notebook, you may choose to have it 2 times the width of the notebook, minus about 1mm.
Put the notebook on the outside sheet, and trace the borders of the notebook on it. be careful with the corners.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:choubbi
