Cheap redneck ceramic smoker
this is a slow cooking smoker. the process takes an overnight soak and most of next day cooking but it is cheap and works better than some hundred dollar metal smoker my neighbor got.
inspired by Alton Brown of Good Eats
Step 1Hardware store time
hardware store time
Hardware includes -
you will need an 2 large terra cotta, or other earthenware non-lead non-glazed planters that fit on top of each other, an electric hot plate that will fit in the bottom of the planter, standard grill grate that fits inside of the "bottom" planter, and a replacement grill thermometer whose probe fits inside the planter hole while the dial can rest on top, a "garbage" pan without a handle or heavy duty pie pan, and wood chips. i bought the planters at the same hardware store as the grate, hot plate and thermometer to make sure they fit together.
Software includes -
1 1/2 cups kosher salt or 1 cup regular salt
3/4 cups molasses and
2 quart of water
1 teaspoon whole cumin seed
1 teaspoon whole fennel seed
1 teaspoon whole coriander
1 tablespoon chili powder
1 tablespoon onion powder
1 tablespoon paprika
last but not least a whole pork shoulder AKA Boston butt 6-7 lbs.
optional -
burger buns
BBQ sauce or my fav pickle juice mixed with some mustard and hot sauce
32 comments
Jan 17, 2011. 4:22 PMvincent7520 says:
Well …
This seems more a BBQ grill with a cover than a smoker : you get the taste of the smoke thru a sauce not thru the process.
I mean, it 's so beautiful to have meat or fish smoked with a very slow consuming (not burning) wood with the benefit that you can keep you meat for a longer time.
After all salt and smoke were the refrigerator of our ancestors before refrigerator time !…
It does not have to take a lot of time, like 24 - 36 hours as they do in the smoking industry : one of the biggest thrill (besides sailing) in our vacations was to smoke the mackerels we just caught on a small stainless steel smoker on the beach or on a quay. We bought it in Sweden about 12 years ago when we sailed there. What you need is ample provision of saw dust (birch preferably, avoid oak, all kinds of pine and all "red" woods…) … line and fish hooks, and a smoker. Our lies in the bottom of the Barfleur harbor (France) following a hazardous jump from the boat to a pontoon by one of the crew member (no I will not give you the name ! And anyway I'rather have a piece of metal in the water than having to recover fast someone who made a bad fall…).
But then, as always, this instructable is so tempting that it gives me the idea of making a new one out of scrap. An other job on the list that is slowly changing into a "wish list".
When project comes true be sure I'll post it (with the mackerel in place !…)
Jul 14, 2011. 7:55 AMclydicus says:
There's "cold" smoking, which is a method designed to preserve food, and popular in Scandinavia for smoking fish. Temperatures around 160 f. for 24-36 hours. Then there's "hot" smoking or BBQ, which is a cooking method designed to make tough cuts of meat very tender, and of course to add flavor.
Jun 27, 2010. 11:30 AMwheelnawheel says:
Most people that make their ideas and inventions public without a patent is because they like to be inspirational and just give things away, whether they get credit for them or not. Alton Brown is a master chef that get's paid very well. I'm glad he had no problem with putting this smoker on his TV show.
Mar 6, 2010. 11:39 PMspylock says:
My smoker will be finished tommorrow providing I can find a replacement cooking grate,I will be smokeing a pork tender loin next Saturday useing your basic method,though I guess we all have our favorite/secret rubs.The finished meat looks very good by the way.
Jan 21, 2010. 8:46 AMthe rural independent says:
I'm wondering about cleaning up afterward.
My smoker (manufactured) has a water pan that all the grease pretty much drips into, so it is all consolidated in one pan and I just have to clean that up.
With yours, do you have much grease at the bottom or does it collect in the wood chip tray - or just burn off?
Great instructable.  Thanks for sharing!
www.theruralindependent.com
Jul 20, 2007. 7:32 AMironsmiter says:
I wonder if the rat's(pets) would like a smoked cornish game hen for thanksgiving, to match the webber smoked turkey? is it the molases that turned your meat black in the final picture(cajun style/burnt?) or was the hot plate just up too high? try adding ONE more step. grab an extra pot and tray at the store while you're there. put the hotplate on the tray. then the pan/woodchips. then invert the extra pot. now put the origional 2-pot smoker over the rig, and fire it up. should also allow you to run your hot plate at a higher temp, meaning better?/thicker smoke production. If you try the three pot method, let me know how the temperature stability of the smoker is effected. by not having the chamber "open" it should retain it's heat better. Glazing should NOT be an issue on your pots. painted pots are a definate nono unless you painted it yourself with engine paint(if your exhaust manifold won't burn it up, the hot plate won't likely either :-) if you know your pot glazing, or glaze it yourself... it should be just fine. defintely avoid lead based glazes. also watch out for bright green glazes that MAY be copper based... if in doubt, avoid.
Jul 15, 2009. 5:13 PMEsmagamus says:
And what about the engine paint? Have you got any idea of what they put in it? Even lead based glazes can become quite harmless if you force them to leach out all of the lead. I wouldn't use it, but I wouldn't use engine paint either.
Dec 19, 2007. 9:12 AMBentSlightly says:
"Hardware includes - you will need an 2 large Terra cotta," Any ideas on sizes of pots that workout to do a turkey? I have seen Terra cotta pots that are gigantic, would a little bigger be better?
Jul 15, 2009. 5:06 PMEsmagamus says:
Get yourself a old wooden chest and poke holes on top of it. I did that so I could smoke about 20 sausages at the same time. Worked too good.
Jun 2, 2008. 9:00 PMM F says:
Will stacking work?> What if I use two smaller pots on top of the big ones for jerky or such?
Sep 15, 2008. 8:27 AMjosephprivott says:
not really, for either. I would use a different method than the one here for Jerky; this is more suited to the meat pictured.
Jul 15, 2009. 5:00 PMEsmagamus says:
Submerge everything in a strong sodium hydroxide solution (careful, it's caustic!). It's such a powerfull degreaser I use it to clean creosote stains on my stine stairs.
Jul 20, 2007. 2:06 AMLasVegas says:
This looks a lot like a Alton Brown, Good Eats eposode. If that's where you got the idea, you should at least give him some credit.
Sep 20, 2008. 5:36 PMFreakin Einstein says:
Forgot? Uhh yeah....Ok.
Jul 20, 2007. 11:02 PMLasVegas says:
Episode's not so important. Since you actually did build it, the Instructable's fine as long as credit is given where it's due.
Jul 20, 2007. 12:54 PMmatt_the_webguy says:
I agree LasVegas, that's a total Alton Brown rig. Give credit where credit is due. Sorry psikot1, just because you used a slightly different pot, you shouldn't pull a "Vanilla Ice".
Jul 6, 2008. 9:54 AMbigcat says:
I learned how to do this 20 years ago in Boy Scouts, so should there be credit listed to them too? Just because someone uses it on TV doesn't make it specific to them. Plus, using Kosher salt has been around for quite a while. So by saying that Alton's use of kosher salt is his trademark, shouldn't people like Emeril Lagasse give credit to Justin Wilson every time he uses cayenne pepper?
Sep 26, 2009. 7:44 AMbfpazza says:
lets get a grip here. neve seen so many armchair lawyers in one place. even alton brown admits on his show these are not his ideas but things he has seen done. still not giving credit to where he saw them done. an idea is not copyright. a patent is only for a new device. u cannot patent a changed device. as well as the credit about the pot from esmagamus? check on the net there are over 2000 manufacturers of these pots. not even an issue. so no copyright, no patent, no trademark infringement. an idea and maybe u guys should just thank him for taking the time to show you.
Jul 15, 2009. 5:01 PMEsmagamus says:
Nice idea. Give credit to the manufacturer of that vase (might be me!)
Jul 20, 2007. 11:07 AMCatMan says:
MUST be Alton Brown material. notice the use of Kosher Salt? it's almost a trademark...
Sep 20, 2008. 5:33 PMFreakin Einstein says:
THIS IS TAKEN FROM FOOD NETWORKS ALTON BROWN...Great idea, I did it myself and it really works. Howver, you should give credit where credit is due. You took Alton Brown's idea, his recipe and his whole half hour program hook, line and sinker and didn't even give him credit for it.....Did you used to sit behind me in Algebra?
Jul 26, 2007. 2:08 PMdoubleabattery says:
Great Instructable! Yes, slow smoked meat is going to be black due to the smoke. I've got a big propane smoker, but this would be a great rig if I was just smoking for a small gathering and didn't want to pay $14 for a propane refill.
Dec 4, 2007. 1:54 AMalexanderm says:
soaking the wood chips prior to use will allow them to smolder, instead of burning... which means you still get a smoky flavor, without the dark blackening.
Aug 2, 2007. 1:52 PMLenny K says:
Question on the smoker. I have all the necessary parts including a 1000 watt electric hotplate. problem is all the ones I've looked at have an auto on/off control so they don't burn up or something. Is there one i can buy that doesn't have that or is there someway to bypass this heat reostat? I can't get my temp above 150 degrees cause it keeps shutting off.
Jul 22, 2007. 8:43 AMindyguy says:
Wouldn't mind seeing some pictures of the finished project ready to eat. It would make a nice cullmination of your efforts.
Jul 20, 2007. 11:24 AMseolfor says:
Looks great. I'll have to try making this.
Jul 20, 2007. 8:11 AMrimar2000 says:
Very good.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:psikot1
