This project is of course, derived from the work that Limor Fried did in her MintyBoost Altoids charger, and from several other instructables, including this project from Joshua Zimmerman. The main differences for this project are cost, and durability. I found that his embedded iPhone charging cable was particularly fragile, with the wires exposed. These issues should be addressed in this instructable.
Here are the components you will need:
- $4.00 - Emergency iPhone charger - via Amazon
- $2.00 - AA battery holder - via RadioShack
- $3.99 - Solar Cell. I used this cell, from Brown Dog Gadgets, but you may be able to find them cheaper.
- Solar Batteries (AA)
- Wire, solder, soldering iron
- Altoids Tin
- Double stick tape
- Electrical tape
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
-Doctordv
Also, you don't need a switch. It's unnecessary. If you wire it all up in Parallel you'll have no problem. Without a gadget plugged in the batteries will charge, with a gadget plugged in the USB circuit will activate and you'll charge the gadget.
Without anything plugged in the USB circuit will draw no power. (You need to cut off the red LED though. No loss there as it's a useless status light anyhow.)
-Doctordv
My question is: will the 4.8v from the AA's be too much for the USB charger to handle? If it makes any difference, I'm using the same USB from the same emergency charger as you.
THanks in advance.
The 4.8V should be fine if you're insistent about going that route. Though it works best between 2-3V.
Thanks for sharing this 'ible! :D
http://www.ladyada.net/make/solarlipo/
They're great for many projects, but they really don't have very kick.
Also, I do in fact have a USB kit with all those same parts on my website (browndoggadgets.com), as well as an instructable that is more or less the same as this one.
Also, if you put a wholllllleeee lot of hot glue over the exposed wires it cements them in place. In case you ever have a problem with them.
