3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
CheapGeek- Make an ugly monitor more or less ugly...
An ugly old monitor- old can of spray paint and waa laa, a more or less ugly monitor. (depending on how you look at it)
I had a spare monitor I used for PC work at the house.
The monitor needed to be black.
Plus everything I have is black anyway.
Step 1Gather Materials
This is an easy instructable- you are basically painting your monitor.
KEEP IN MIND- MONITORS STORE RESIDUAL ENERGY, EXERCISE EXTREME CAUTION.
You need an ugly monitor, tape, spray paint, screwdrivers, work area, drop cloth or towel.
Get your work area ready.
8 comments
Apr 16, 2010. 8:12 AMzim_256 says:
You're doing it wrong!
It may look well for some days but the most minimal scratch will expose a white unpainted area, tried this with a beige PC to make it black.
You need to use better painting techniques when painting plastic, first using a primer, then the color and the finish.
Dec 20, 2008. 12:51 AMtuckwood123 says:
I think your mod is REALLY DANGEROUS as you are exposing high voltage capacitors. If you touch one you couold get a nasty shock. Plus CRT monitors contain alot of harmful lead.
Mar 9, 2010. 12:00 AMhellstudios says:
as long as you don't TOUCH anything inside the CRT you're fine, along with the lead.
Jan 5, 2008. 8:30 AMkretzlord says:
There's a product called vinyl spray paint that, while costing a little more, gives an awesome color coat. It flows through all the little bumps that monitor cases have to offer a little better than spray paint. You can get it at most automotive stores. (or if it just doesn't matter, pick up the $1 can -o- spray paint).
Jan 11, 2007. 5:41 PMmark101 says:
An open monitor is not that dangerous if its unplugged from the 120vAC. The only danger is if you discharge the high voltage charge on the CRT (like a capacitor)which can stay for days , depending on the relative dirt and humidity in the area. Its a thick red wire going from the (flyback)tranformer to the top back of the glass tube. You can wipe the dust off it if you like but don't tug on it hard. It has expanding spring clips inside that keep it attached to the glass tube.It could kill you. Be sure to videotape yourself, if you plan to unsafely unplug the wire, so people will know how you died.
Jan 10, 2007. 12:19 AMpablo says:
Voila. It's voila.
Jan 9, 2007. 2:18 PMfrank113 says:
I was really thinking about doing this to my old CRT last night, it looks good, i think I'm going to paint mine later tonight, nice job!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:cheapgeek(CheapGeek)
Cheap... Geek
