Step 5: The actual bank
Remember all those disposable cameras? Pull the capacitors out, I got 4 caps rated at 330volts and 120µFarads. Make sure the gray stripes are all pointing in the same direction, and get out some of that 12AWG wire. As you can see in the picture, I stripped only part of the wire. To do this, make the circular cuts like you usually would, then take a razor blade and slice down the middle. Then just peel off the rubber, it's way easier than it sounds.
Now using a small screwdriver, push throught the copper strands making a slot the capacitor leads can go through. Put em through, and then solder, it's that simple. I reccomend making both wires first, then soldering all the caps onto one wire, and then the other wire. It's easier that way.
Remove these ads by
Signing Up
Visit Our Store »
Go Pro Today »
...............................DON'T DO IT!!!!!!!!!!................................................
but if your going to do this project use it on a coil to make a coil gun
TIP: if your going to make a coil gun with several capacitors IT MUST SWITCH FROM PARALLEL TO SINGULAR or the full power of the cap wont be released
