Cheap'n'Easy Airsoft gun bore cleaning rod by JerryMopar
Everyone that knows a bit about airsoft knows that you need to keep your gun clean and lubricated in order to maintain good accuracy. One of the most critical areas in keeping accuracy high is a clean inner barrel.
If your new to airsoft, you might be hard-pressed to spend another $10-20 for a proper .22 cal  gun cleaning kit. But fear not, this cheap and easy bore cleaner rod will get the job done!
Step 1: Supplies
Here is all you need
some basic Q-tips
1-2 straws (depending if you have a long barreled gun or a short barreled gun)
The straws must be small enough to have an interference fit with the Qtip
Bore cleaner and lube (You may use rubbing alcohol and Silicone oil, respectively)
zack attack says: Jun 11, 2011. 8:32 AM
Dudes, don't buyfrom crosman. save up some extra money and get a jg m4 cqb for 140 dollars. if u think thats expensive, theres a socom gear barret m82 for 1,200. echo 1 minigun for 3,500.
AlphOscarAlpha says: Feb 2, 2011. 1:37 PM
I have that same gun. Mine has clear parts on it, though.
1we says: Apr 28, 2011. 1:42 PM
Is it by Soft Air?
That gun looks like mine. Mine is By Soft Air (Cybergun) though. Great gun!
Thanks!
lowe says: Mar 11, 2011. 8:01 PM
I dont need to spend money on one of those, all my guns come with those
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
