Cheap/upcycled Shopping Basket Stool
347
Published
Introduction: Cheap/upcycled Shopping Basket Stool
About: I graduated from Cardonald College with an Advanced Diploma in Graphic Design in 1999. He has worked as a Tattoo Artist, Community Artist, and Freelance Artist ever since. I like making instructables that ...
Hello Instructablers!
In this instructable we are going to be making a bit of up-cycled furniture.
Its cheap, takes around 10 mins to make and uses hand tools.
It also helps tidy up your area a bit which is also a good thing.
Lets get started...
Step 1: What You'll Need
Materials
Metal shopping basket. I hope it goes without saying DONT STEAL THEM! tend to be you can find them discarded all over the place. when you do find one hopefully its not too beat up
Brush pole. I picked up one at the local hardware store for £1.50
Cable ties. Pack of 100 cost me £1 and we only use 12
Tools
A saw
Scissors
Measuring tape
Pencil
Step 2: Making Your Legs
Now for this i am using one brush pole, you could make the stool taller by using 2 but keep in mind the taller you make it the less structurally strong it will be and take up more floor space as the legs splay out the way (you'll see what i mean next step)
Measure your brush pole and park it into quarters with the pencil.
Saw the pole into four pieces.
Note: If you want you can saw the legs at an angle so the ends are flush with the floor/basket but for simplicity I just cut them straight across.
Step 3: Attaching the Legs to the Basket
Important! make sure your handles are away from the edge of your basket as you attache the legs as they will get trapped there once you cable tie the leg in place.
Keeping the leg tight in the corner cable tie it in place at the lowest horizontal wire on the side of the basket and around the vertical wire.
Repeat near the top of the basket.
Lean the handle against the leg and cable tie it to the leg.
Repeat for the other 3 corners.
Trim away any excess cable tie.
Step 4: Finished!
And we're done.
Its surprisingly comfortable but you can always add a pillow to it. It can double as a foot rest and (in my opinion at least) looks cool
and best of all it cost under £3 to make.
I hope you enjoyed this instructable and as always thoughts/comments/criticisms and photos of your own creations are welcome in the comments section below
Bye for now :)
    • Stick It! Contest
      Stick It! Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    2 Comments
    I can definitly see that working :)
