3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheapy Lighter Laser Burner
Step 5Final Lighter Prep
Final Lighter Prep
There are two main holes at the top of the lighter.
One is the where the red button you removed earlier makes contact with a valve to release the butane and on the other side where the flame exits.
Both of these holes need to be drilled out to accommodate the switch and the mini-diode housing. Use drill bits and CAREFULLY drill the holes out. (A small bit will be needed to drill out the little valve.) Don't worry about the center area where there is another hole. Stay away from the brackets in the middle because you will need those to reattach the red button later.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2394
Author:Kipkay(Kipkay Videos)
Tinkerer, hackster and prankster. Hit me up on Facebook: http://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
