Step 6Building the Circuit
Wire the driver according to the following picture. The second picture is the flip side of the driver.
Be sure to add the resistor and the switch as show in the the final wiring pic.
Using a multimeter set to check milliamps, put the leads between the end of the resistor and the diode. Power it with no more than 3 volts and adjust the pot on the driver to no more than 170 mA. I used 2 button cells, taped together on the sides, harvested from an Energizer 12V 123 battery I also used two small magnets to attach the (+) positive and (-) negative leads from driver.
Thanks!
Anyway, I already have removed the on-board momentary switch, so I don't know how viable it would be to use needle-nose pliers, but I do know that if you use tweezers, and grip the very bottom of it, then rock it slowly, gently, and especially carefully, left and right, you might be able to snap it off without damaging anything (except said switch that you would probably discard). That's how I removed it, and I don't think anything is damaged. --Yet.
Good luck!
here is a way to make your own circuit. (it's very noobish though)
http://www.metacafe.com/watch/1011559/diy_how_to_make_a_laser_diode_driver_circuit/
