Checker Duct Tape Wallet
9,942
35
12
Posted
Introduction: Checker Duct Tape Wallet
This is a checker board pattern wallet that I decided to make one day when I was bored its not hard to make, but it's not easy. It took me about an hour to make but i've made a couple so its easier to make. Enjoy!
Please comment if you like it or don't like it or have some ideas that could make it better! :)
Step 1: Supplies
You will need:
3 colors of duct tape (Grey/Normal color for 3 color recomended) or 2 it doesn't matter
Ruler
X-acto blade (#1 blade best)
Sheet protector (for see through card holder)
Cutting surface
Step 2: Main Pattern
First lay down 2 strips of duct tape 10 in. long and as close together as possible without overlapping. Next cut those strips in half so you have 4 thin strips.
Now take your second color and lay down a long strip that you can cut up into 5 41/2 in long strips. Now take that strip and cut it in half so you have 10 thin strips... you may discard the 10th strip because we only use 9.
Now weave them in and out as shown in the pictures and continue to do that with all 9 strips until it looks like the main picture below. Cut off any excess on the top but just clean up on the bottom you will need those tabs later.
Carefully peel it off of the cutting surface at an angle as shown in the pictures.
Now cut a strip of paper the exact size of the woven pattern that doesnt cover the tabs. Now take your 3rd color and cut 2 strips 10 in. and cover the paper.
Step 3: Making Money Pocket
Take your first color and lay down 2 strips of it (10 in.) only overlapping a little. Now peel up and take 3rd color and put on sticky side. Now with those tabs that weren't covered earlier on, attach the piece we just made to the rest of the wallet by those tabs.
Now you can put money in it but you probably want some extra features in there like ID card holder. card holders and a coin pocket.
Step 4: Card Holders
For this part you may want to use a card for an example size.
First take 2 strips of duct tape (about 3 creditcards width with an inch of surplus) and overlap them a little again, cut it down to alittle shorter than the card. Now on the far right bottom hand corner make a small cut out of it (this is so one is higher). Then fold it so you have 3 card slots and tape the edges and tape it to where you want on the wallet. If its too big then you can cut off excess as needed.
Step 5: ID Card Holder
Take your sheet protector and make a rectangle a little bigger than a card. Then basically tape it down to where you want.
Step 6: Coin Pocket
This is the last real step to make your wallet complete! Just make a small strip a little shorter than the wallet is and tape that down! Now you are done with the wallet!
Step 7: Put Under Weight
Just put it under something heavy and leave it there over night or put it in your back pocket and sit!
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    12 Comments
    I used the thing about checkering to checker the duct tape wallet i already had :)
     how do you get the edges so neat and the side edges small? i selling these at skool and i need to make it neater
    ok this part is really confusing to me...
    this is great ty
     or put it under your mattress under night
    This is a very nice tutorial.
    I made mine following this loosely, choosing to make it bi-fold instead of tri.
    Just put the card holder on one side, and the ID/Coin pocket on the other.
    Excellent job on the checkering help.
     Thank you, I'm coming out with a bi-fold wallet soon and they are really good if you make it right it'll last you at least a year!
    can you make it a little moreclear to understand! no offense.
     I will try but I'm not sure how to make it more clear though
