Cheerio Ant Feeder
Published
Introduction: Cheerio Ant Feeder
In this instructable, you will be assembling a feeder for ants. The cost to operate this feeder is much more economical than most other ant feeders you will find on this site. I hope you will enjoy the many pleasures of feeding ants.
What You'll Need:
  • a Cheerio (you will need to acquire an entire box of Cheerios from your local supplier)
Step 1: Selecting Your Cheerio
Selecting the right Cheerio for your ant feeder is surprisingly simple.
  1. Reach at least one hand into the box of Cheerios. Using your fingers, gently remove one Cheerio from the box.
Hint: Honey Nut variety works very well.
Step 2: Constructing the Feeder
To construct your feeder, first double check that you have gathered all necessary components from the list below:
  • an individual Cheerio
If you find that you have forgotten any of the parts you will be needing, this would be a good time to go back and collect them.
If you have everything, great! and let's go!...
The construction of the ant feeder is very straight forward. However, if at any point you feel the parts aren't quite going together correctly immediately stop. The components you are using are very delicate and could be rendered unusable if damaged.
Assembly Instructions:
  1. Place your Cheerio on a floor. Your kitchen will probably be the best floor to choose for this step. If you don't have a kitchen, a driveway sometimes works well.
Step 3: *Updated & Revised Version (8/29/15)
Over the past one day, I have received much feedback suggesting that this feeder may function at a higher feeding effectiveness if you were to utilize 2 Cheerios. (see photo) However, please keep in mind this will double the cost of operation.
    • Pets Challenge
      Pets Challenge
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    Thank you for your suggestion. It is brilliant. I have updated and revised the instructable to reflect your proposed changes.
    By inserting a toothpick into a cube of cheese one would be stack multiple cheerios.
    yes, for an advanced DIY'er that's a good idea ...but for me that sounds overwhelming.
    I tired to make it my way but I couldn't figure out how to get the toothpick in the cheese. Then when I finally got that done I kept missing when I tried to put the cheerio's on the toothpick. 4 hours is enough. I'll stick to your method. I forgot to K.I.S.S.
