Steelers fans, here's one for you: Devonshire Sammies.
Ingredients
1 Pint Skim Milk
1/2 Cup Heavy Cream
1/8 Cup Lemon Juice
salt
Step 1: Heat
- Combine the milk and cream,
- Heat in a saucepan over medium heat until it is about to boil, around 190 F.
Step 2: Curdle
- Remove the saucepan from heat.
- Allow milk to cool slightly, about two minutes.
- Add the lemon juice to the milk, gently stir to mix.
Step 3: Separate
- Allow the milk mixture to cool to room temperature, this will take an hour or two.
- Line a fine mesh sieve with cheese cloth.
- Pour the milk through the cheese cloth catching the cheese curds.
- Allow liquid to drain.
- Salt to taste
- Form a ball. wrapping cheese cloth around the curd. Gently squeeze out liquid.
Step 4: Press and Firm
- Place the cheese cloth wrapped curd in between two plates.
- Set a heavy can on top of the upper place.
- Refrigerate until cheese curd is firm, occasionally dumping drained liquid. This step will take 3-5 hours.
Step 5: Cut and Prepare
- Remove the curd from the cheese cloth.
- Cut your fresh cheese curds into the desired sizes.
Prepare. Cheese curds are used in different ways:
- Battered and Fried
- Poutine
- Crumbed on Salads
- Enjoyed plain
- etc...
To batter and fry as pictured on the first page:
- Mix equal parts chicken broth (or beer) and flour.
- Dip curds in batter and fry between 400 and 450 F. Be sure to use an oil with a high smoke point, such as refined peanut oil.
- When curds float, remove and cool on a paper towel lined plate.
Visit Our Store »
Go Pro Today »
The flavour of cheeses develops over time, and depending on the conditions the cheese is matured in. Cheddar is a hard cheese, that matures for a long time, allowing little acidic crystals & really rich flavours to develop.
The curds for cheddar would be the same as this - there's nothing to distinguish most cheeses at the curd stage, all the flavour develops after that.
"Mix equal parts chicken broth (or beer) and flour."
Equal Parts weight, or Volume?
Fastigheter
I got ten white handkerchiefs at wal-mart for a few dollars. I boil one of them first, and then use them as you do cheesecloth to strain the whey.
What I don't understand is why you mix skim milk with heavy cream instead of just using whole milk. I suppose if you keep skim in stock at home this might make some sense.
I'll probably just add the battering and frying instructions to the end of this instructable later today.
