3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cheeseburger Made In A Rice Cooker
Step 25 Steps, Under 10 Minutes
STEP 1: MARINATE THE PATTY
Scoop 1/3 lb. ground beef into plastic bag
Add 1 pinch (fried) garlic
Add 1 pinch (fried) onion
Squish bag
STEP 2: HEAT
Turn on rice cooker
Wait to heat up
STEP 3: PLACE
Place patty into rice cooker
Wait for 5 minutes
STEP 4: OTHER SIDE
Turn over
Wait for 3 minutes
STEP 5: FINISHING TOUCHES
Remove from rice cooker
Add toppings
Serve and enjoy
7 comments
May 29, 2010. 1:16 AMreverendbubba1 says:
Just had to ask...does this seal the flavor in,as opposed to just frying it???
Jun 11, 2010. 1:04 PMtayerst says:
No, it does not "seal" anything in because that never happens. What is it that you think happens during *any* cooking process? Are you hoping to create an impervious layer like plastic? Maybe we could increase the intensity of the gravity-well at the center of the burger such that juices leak IN instead of OUT? ;-> If you seared your hand would your bodily fluids be more or less visible? No, the whole notion of "sealing the juices in" is nonsense. Searing (done properly) causes browning reactions which yield yummy compunds. Frying something dipped in batter could conceivably slow the loss of (some of) its contents. But if you want to "seal" your food you'll need to use foil or plastic wrap.
Oct 13, 2010. 8:15 PMMesmerize says:
sear a steak, then finish under a broiler. then just throw a steak under a broiler. which is juicier? the one that was seared first.
does searing "seal in" anything? no. does it slow/reduce moisture loss? most definitely.
May 24, 2011. 9:37 PMX800xt says:
Also, lots of the gastropub type burgers are cooked entirely under something like a salamander.
May 24, 2011. 9:34 PMX800xt says:
Searing doesn't reduce moisture loss, in fact it increases moisture loss. When high heat is applied on meat, the protein strands in meat coils and tightens up. What happens then is water is squeezed out, like wringing wet clothing. When searing, so much heat is applied that the outside develops a dry exterior while cooking the insides. As a cook finishes with lower heat, the same amount of moisture escapes, so losses at searing are greater. However, The loss of moisture is barely higher than meats cooked without searing to warrant no textural difference. Why do we sear? Simply because that brown, dry, crusty outer layer is flavor.
Dec 20, 2010. 8:44 PMams0027 says:
I tried it but it was a little too chewy
Dec 20, 2010. 11:13 AMchristophungus says:
nice!
Jun 20, 2010. 3:00 PMmenahunie says:
Real good way to kill your rice cooker just to fry a hamburger. She's in a college dorm and depending on dorm policy allowing or not cooking in your room. I find it better to just take my frying pan to the common kitchen and fry up a bunch of patties, freeze them then nuke them in the micro when I want one.
May 13, 2010. 9:54 AMmarjorieallea says:
 Cool!!!  This reminds me of college dorm days, when you could stay in the dorms during the summer and the cafeteria wasn't even open, and we fried potatoes, onions and chicken legs (yes chicken legs) in the base of an old fashioned popcorn maker!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:madeinaricecooker(Jeanelle Mak)
