Introduction: Cheesy Potato Fries
Picture of Cheesy Potato Fries
Who doesn't love french fries, potato fries or any kind of fried potatoes! I'm not a good cook but I enjoy trying different recipes for potato fries and they always taste good (no matter what the recipe is!). I've posted an ible of spicy potato fries, and this time I tried mixing a little cheese with the potatoes. They taste delicious!
Lets' start :D
Step 1: Ingredients
Picture of Ingredients
To make the cheesy potato fries you'll need:
1) 3 medium size potatoes,
2) Half cup flour,
3) Salt (for taste),
4) Dairy cheese (as much as you want),
5) Grater,
6) Unused oil for frying (I used soybean oil).
Step 2: Cutting the Potatoes
Picture of Cutting the Potatoes
Peal and cut the potatoes as it is usually done for french fries. It's nice to keep the sliced potatoes long and thin, so cut the potatoes horizontally.
Keep the sliced potatoes on a bowl or pot filled with water while you prepare the other ingredients.
Step 3: Making the Paste
Picture of Making the Paste
Take a bowl, add half cup of flour and enough water to make the paste. Also add a bit of salt (1/4 tbsp or as much as you want).
Now, grate the cheese and mix it well with the paste (as much as you want).
Then, add the sliced potatoes to the paste and mix them well.
Step 4: Frying and Serving
Picture of Frying and Serving
Take a medium pan or pot and add enough oil to fry the potatoes.
Heat oil over medium heat.
Once the oil is heated, add the pasted potatoes to the pan.
Don't stir frequently while frying, and after 5 -8 minutes turn the potatoes around to make sure they're fried evenly on all sides.
It'll take 8-10 minutes after that and don't let the fries turn brownish. Use a slotted spoon to take the fries out of the oil and place them on a napkin to soak the oil. After frying the potatoes you can sprinkle more grated cheese on them if you want to. Serve them with cola and tomato ketchup!
They're delicious!
Enjoy!
zaid.bro (author)2014-04-23
can i use frozen uncooked fries?
Muhaiminah Faiz (author)zaid.bro2014-04-23
Sure, you can.
i surely will try making this recipe ?
A Maker (author)2013-07-24
I made these the other day and they taste soooo good
Muhaiminah Faiz (author)A Maker2013-10-06
Thanks for following my recipe! glad you like it :)
ammaar9 (author)2013-07-24
so cool
chaitanya.vedak (author)2013-07-22
These Look delicious.. I probably might add a bit of Oregano, and Chilly Flakes to it, in the Batter mode, and then coat the strips, and then Fry.. Might add a zing to it..
Thanks! your recipe sounds great as well! thanks for sharing :)
You're Welcome
8steve88 (author)2013-07-22
Made me hungry!
I don't eat French fries or chips very often but when I do they've got to be cooked in beef dripping or lard, same as pancakes though with pancakes just a wiping of the hot pan is enough lard.
You just don't get the flavour with oils that you do with lard and as I say I don't eat chips, - French fries in the U.S.A but not quite chips.
Good recipe though.
danzo321 (author)2013-07-21
OK, I realize you come from somewhere but you say '1/4 tbs salt." You have got to use American cooking conventions here. Teaspoon is "tsp." Tablespoon is "tbsp" I think. We don't usually divide tablespoons into quarters; 1/3 of a tablespoon = 1 tsp.
legless (author)danzo3212013-07-22
Er no we dont have to use American "cooking conventions" or standards for anything in here. The majority of the world uses milligrams, grams, kilograms and tonnes, millimetres, centimetres, metres and kilometres. Some may choose to add other units as a courtesy to save you having to convert. Any abbreviation for teaspoons or whatever that are acceptable and understandable are fine to use. As for the number of teaspoons in a tablespoon it depends on where you are which is why we tend to measure in millilitres here. In America and Canada: 3 (5 ml) teaspoons = 1 tablespoon (15 ml). In Australia and the UK: 4 (5 ml) teaspoons = 1 tablespoon (20ml).
Muhaiminah Faiz (author)danzo3212013-07-21
Extremely sorry! I meant tablespoon. you need to add a bit of salt just for taste, so I used 1/4 tbs (but missed the 'p' and it was a silly typing mistake!).
danzo321 (author)Muhaiminah Faiz2013-07-21
OK, and how did you measure a quarter of a tbsp? I can't do it.
Muhaiminah Faiz (author)danzo3212013-07-22
If you can't measure a 1/4 tbsp then simply add a small amount of salt. 'salt for taste' means adding a small amount of salt to reduce bitter flavors and make other flavors pop, it definitely doesn't mean that we're looking for a salty flavor.
lamerc (author)danzo3212013-07-21
Well, you don't *have* to use American measurements here (after all, you understood exactly what she meant :).
Also, while we're talking "to taste" and I can't imagine it's critical here (as it might be for something like heavier spices or baking powder), 1/4 isn't the same as 1/3. If a recipe in an American cookbook actually needs 1/4 tbs, then that is the way they'll write it.
(And, per Wikipedia, "it is abbreviated as T, tb, tbs, tbsp, tblsp, or tblspn", so as long as it's either a cap or you get the "b" in there, you're pretty much cool. :)
danzo321 (author)lamerc2013-07-21
No: we seem to understand this differently! I THINK she means teaspoon. And we do not divide tablespoons into fractions, never seen such measures. And can't salt to taste this early in the recipe.
(oh, and I have seen 1/4 or 1/2 *T* listed, but only when a very precise amount is needed and rounding to the nearest teaspoon won't work.)
Ah, yeah, that would make a difference.
1/4 teasp is an *awfully* small amount, though, especially for potatoes. (And I was going with the "to taste" from the ingredient list, you're right about the steps.)
You don't identify the potatoes used but debate is furious over Yukon Gold vs. other varieties. Main thing is, you're not using red potatoes.
Any kind of floury potato with a dry texture is great for chips (or fries if you will) - King Edwards, Maris Piper, Romano, Desirée, russet Burbank potatoes, bintke or spunta potatoes. And yes tbs is a perfectly valid abbreviation and I have seen 1/4 of one used in a recipe before. You just seemed really intent on picking on every little detail of this recipe. Just in case you weren't sure one should use an oil than can sustain a high temperature without smoking.
I used yukon gold but I think you can try this recipe with other types as well.
veruca_salt890 (author)2013-07-21
I want to make these on chili night and have chili cheese fries. <3 They look so good.
Thanks! glad to know :)
Adam_D (author)2013-07-22
Sounds awesome. What temperature should the oil be at? Thanks!
Muhaiminah Faiz (author)Adam_D2013-07-22
Medium heat is perfect for potato fries, it's 325°F to 374°F. No problem!
maka (author)2013-07-21
Here, I use Parmesan and also add freshly ground black pepper to the batter, then sprinkle with more Parm when they're done and finish with a very fine drizzle of truffle oil. Mmmmmm.
Muhaiminah Faiz (author)maka2013-07-21
Sounds delicious! I'll try :)
Tchr4vr (author)2013-07-21
Thanx for all the great ideas !
Muhaiminah Faiz (author)Tchr4vr2013-07-21
You're welcome! :D
platdujour (author)2013-07-21
How about adding some chipotle chilli flakes to the cheese mix..?
Sounds great! give it a try :)
vincedavis (author)2013-07-19
I will try this
billbillt (author)2013-07-19
YUM!!!!!
Hannah Hudson (author)2013-05-31
Yummm! Now I'm really hungry!=P
ohh, you should try this!
BrittLiv (author)2013-07-19
They look extremely good, but you should definitely replace your cutting board.
Muhaiminah Faiz (author)BrittLiv2013-07-19
Thanks! yap, already did, that was the last use of it! :)
oliviastewart (author)2013-07-18
Mmm cheese. Can you taste the cheese well in this recipe?
yes, to get a better taste of cheese you can sprinkle more grated cheese after frying.
crazylam15 (author)2013-06-24
I have to try them.... They look so tasty
Thanks! let me know if you like'em :)
Tarun Upadhyaya (author)2013-06-01
Wow...They look mouth watering :).
Thanks! they really are :)
Haha, thanks! you should try some :)
Yashfa Zafar (author)2013-05-31
they look very tasty!
They do! thanks :D
jessyratfink (author)2013-05-31
Wow these sound amazing. :D I think I might need to give them a try!
They're really tasty! Thanks :)
About This Instructable
54,624views
672favorites
License:
Bio: Hey, I'm Muhaimina! A crazy craft addict! Obsessed with swirls and polka dots... Love green craft and rustic home decors... and Instructables is pretty ... More »
More by Muhaiminah Faiz:Prepare Spicy Chicken PopcornDIY Paperclip RingDIY Easy Paper Hyacinth Flowers
Add instructable to:
