Introduction: Cherry Dangling Earrings
I've got another tutorial to share :)
Step 1:
Cut 1 x 14cm (5.5 inches) 0.8mm (20ga) wire. With your round nose pliers grip the wire at the center. Bend both wires crossing each other to make a loop.
Step 2:
Make the 2nd loop, wrap the left wire onto the round nose pliers by bring the extended wire in clockwise direction.
Step 3:
Then slide in your 6mm round bead. Using your thumb and point finger, carefully wrap the wire onto the bead going inward or counter-clockwise direction.
Step 4:
Make the 3rd loop, wrap the wire onto the round nose pliers in counter-clockwise direction. Wrap the bead again, but this time wrapping in clockwise direction.
Step 5:
Attach a jump ring on each loop then hook the 2 jump rings into another jump ring together with your ear wire.
Step 6:
Make a dangle using ahead pin. Slide the bead and make a loop with the excess wire. Then attach a jump ring and hook it up into the 1st loop.
Step 7:
Repeat the steps and create a pair. Voila! You've got a yummy-looking Cherry Dangling Earrings.
Hope you like this short tutorial. I have a more complete steps on my blog. Visit my blog to DOWNLOAD A FREE PDF COPY.
