When it comes to an iPad stand (making one, buying one or adapting something), the possibilities are endless if only for the simple plainness of the f...
I was lucky to find a scrap piece of cherry wood in my workshop. Cherry is a hardwood with fine grain and polishes nicely to an amazing smoothness. As...
The board I found measured almost six inches wide (S3S), making it perfect. The wider the better for supporting the iPad, but anything wider than the ...
And this is 5/4 board, meaning it's nominally five quarters of an inch thick at the lumber mill. Actual thickness varies by species. This piece actual...
Depth of cut is set to about half the thickness of the 5/4 cherry stock, giving a decent half-inch "bite" to hold the iPad and leaving a good half-inc...
I wanted an access hole for the docking cable. The perfect width of slot (to hold the New iPad or "iPad3") turns out to be about 3/8" so I fitted my ...
The sculptural form and appearance of this simple stand when viewed from the front (the usual appearance) would be nicer if angle cut. So I cut off a ...
Sanding took me the longest time. This is, after all, cherry wood where sanding achieves superior surface texture the longer you work it. Not shown is...
The bottom of the slot cut is the least concern. There's no need to shape the slot bottom for precise fit of the iPad's edge. It only needs to be deep...
Landscape orientation looks okay — there's no obstruction of the visible screen. The bezel margins are actually narrower in landscape mode than in por...
This is the wood stand mostly complete, though still unfinished (to get tung oil). I can optionally cut another slot at the other end for an alternate...
I think the simple beveled front is elegant enough. The 5/4 stock looks beefy but not overkill. The polished (finely sanded) cherry end grain also loo...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
