Introduction: Chess Pawn
Picture of Chess Pawn
In this lesson, you will learn to design a traditional chess pawn!
Let's get started!
Step 1: Let's Get Building!
We need a shape to start with. Let's start building!
Instructions
  1. Drag a cylinder shape to the workplane.
Step 2: Adjust the Height
Let's adjust the height.
Instructions
  1. Scale it smaller to a height of 3mm.
Step 3: Add a Workplane
Let's add a new workplane.
Instructions
  1. Drag a Workplane to the top of the cylinder. (Shortcut = W)
Step 4: Grab Another Shape
Let's add a cone this time.
Instructions
  1. Drag a cone shape to the top of the cylinder.
  2. The new shape will land on the workplane you just created.
Step 5: Make It a Bit Shorter
Scale shape to be a bit shorter.
Instructions
  1. Scale the shape shorter to a height of 11mm.
Step 6: Add a Sphere Shape
Add a sphere shape to the workplane.
Instructions
  1. Drag a sphere shape to the workplane.
Step 7: Squish It!
Let's make the sphere a little smaller and squish it.
Instructions
  1. Scale the sphere to a diameter of 18mm.
  2. Squish it! Scale it shorter to a height of 5mm.
  3. Move it to the target area in orange.
Step 8: Add Another Cone Shape
Let's add a cone shape.
Instructions
  1. Darg a cone shape to the workplane.
Step 9: Tweak the Cone
Let's adjust the shape of the cone.
Instructions
  1. Scale it to a height of 28mm.
  2. Scale it smaller to a diameter of 14mm.
Step 10: Position the Cone
Let's position the cone.
Instructions
  1. Move the cone to the target orange area.
  2. Lift the the cone 3mm off the workplane.
Step 11: Add Another Cone
You will need another cone.
Instructions
  1. Drag another cone to the target area in orange.
Step 12: Size the Cone
You will need to adjust the size of the cone.
Instructions
  1. Scale it to a diameter of 12mm.
  2. Scale it taller to a height of 19mm.
Step 13: Flip the Cone
Rotate and position the cone.
Instructions
  1. Rotate the cone 180 degrees.
  2. Move it to the target area in orange.
Step 14: Add a New Workplane
Let's move the workplane.
Instructions
  1. Drag a workplane to the top of the cone. (which is really the bottom of the cone you just flipped)
Step 15: Add a Sphere
Add another sphere to the workplane.
Instructions
Step 16: Size the Sphere
Let's get the sphere sized right.
Instructions
  1. Scale the sphere to 8x8x8mm.
  2. Tip: Holding shift on the keyboard will scale the shape in all directions.
Step 17: Reset the Workplane
Let's clear or reset the workplane.
Instructions
  1. Drag a workplane to the original location of the workplane.
  2. Tip: Place the workplane anywhere, except on a shape to reset it.
Step 18: Align the Shapes
If you didn't keep everything perfectly aligned, that's ok!
You can align the shapes now.
Instructions
  1. Select all the shapes.
  2. Click the Align button on the menu.
  3. Align the shapes to the middle on the front and side.
Step 19: Group the Shapes
Select all the shapes and group them.
Instructions
  2. Click the Group button on the menu.
  3. Tip: You will know if the Group action worked if all the shapes all become the same color.
Step 20: Congratulations
Great Job! You made it!
About This Instructable
354views
0favorites
License:
More by tinkercad-support:VEX IQ: Clawbot ScoopBalloon Powered CarExplore Buoyancy: Designing Sea Craft
Add instructable to:
