Introduction: Chess Set From Wood
For my next project I decided to make a chess set from wood. I have seen many examples on Instructables.
I used Meranti for the dark pieces and Pinewood for the other pieces and the border.
Step 1: The Original Pieces
Meranti and Pinewood from the shop, I bought a little too much but maybe I'll make a second one.
Step 2: Sawing to the Right Size
Sawing the pieces to the correct size and gluing together.
Step 3: Sawing Again
Sawing the board in pieces to glue it again.
I made 2 sections too much to slide the even numbers up.
Next time I won't make too much sections and turn the even numbers around to save wood.
Step 4: Gluing Together
Gluing the pieces together.
Step 5: The Framework
For the framework I used a router for making a groove to make the board equal with the framework.
I used angled cuts for the corners.
Step 6: Finishing the Board
Gluing the framework together with the board.
When it was dry I sanded the whole board to make it equal and remove rests of glue.
Step 7: The Pieces
I don't have many steps for making the chess pieces, but they are made from the same wood.
They are a little bit minimalistic because i don't have a lathe.
Step 8: The Result
8 Comments
Nice
realy nice chess set.....will try this myself
Thanks, and succes!
How long do I cut the boards
Each section is 3 cm. So each row is 24 cm long.
LOVE IT! I've been looking for one that was simple. Thanks for the ideas.
Nice set...simple and elegant.
Thanks!
