Chess/Checker Set from Remnant Marble/Tile and Duct Tape...Pick Your Color!
 by joanstanescu
Featured
You will love playing chess/checkers with this colorful board made from remnant 12"x12" marble(as shown here) and decorative duct tape! Personalize your own  board with wonderful colors and designs.    Spare coins can serve as checkers or chessboard pieces!
Please take our survey (answer questions concerning chess/board part of survey):
http://www.surveymonkey.com/s/G3WKLC3
Step 1: Use Rubber Bands to Guide Your Placement of Duct Tape Squares
Wrap one rubber band at a time in parallel rows across the 12” x12” tile, starting with the first in the center (add more from the edges, so it takes less time to roll). You can use any rubber band as long as all the rubber bands are the same size and stretch cross the marble to cover only a thin area.  Space them evenly till they are 10/8th inches apart from each other(use a ruler to check spacing). The two end rubber bands however should be spaced 1” from the edge of the tile.
timm.tanner says: Aug 14, 2012. 9:40 AM
You could combine this with Mrbellangs instructable for duct tape dots - http://www.instructables.com/id/Duct-Tape-Quick-Dots/ - and then use the paper cutter to get your squares made fast. Cool look!
mikeasaurus says: Aug 13, 2012. 5:41 PM
Psychedelic game board, I like it!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
