3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Childhood Laser: Building a HeNe Laser Kit
This is about building a Class II <1mW Helium-Neon (HeNe) laser. It's also about a dream that's been a long time coming. A little back story would help.
As a kid, back in the 80s and 90s, I used to get Elenco electronic kits from my Dad and Mom as presents. I had them all, the Digital Roulette (K-25), the Space War Gun (K-10), the Pocket Game Dice (K-28) and many more. Even a few robot kits. Then I discovered lasers and all I could talk about for months was getting the brand new Class II Laser Kit (LK-1).
Of course lasers are dangerous and so both my parents said no, responsibly. I continued to pester them and a deal was struck: I write a report on lasers, about their history and safety, and they would buy it for me. So I went to the library, studied up on lasers, wrote the report, and in 1992 I got it. I was so happy I couldn't believe it.
Well, as chance would have it, I lost the instructions and we put off building the kit for a while. Then the whole thing got forgotten and packed away, lost to me for about 15 years. I found it about 5 years ago while I was moving and surprisingly everything was in mint condition. The instructions were still lost and so I checked the internet every year seeing if the schematics would pop up but they never did.
You see the board has no markings and I didn't have a full parts list, only the parts in the box. So the best I could do would be to reverse engineer the circuit, something I'm not great at. A picture would have helped tremendously but I couldn't even find one of those. Finally I tried looking at the Way Back Machine for even the smallest clue but only found this:
http://web.archive.org/web/19970125020504/http://www.elenco.com/dlxkits.htm#lk1
With all hope lost I finally decided to write Elenco for help, hoping that they had the 20 year old plans in their archive. I probably should have tried that first but it never occurred to me. Well wouldn't you know they sent me a PDF of the schematics and instructions the very next day! Suddenly I became a 12 year old again, giddy with excitement. So here I am ready to make a 20 year old dream come true and build that laser kit I begged for as a kid.
So if you're ready then come watch me build this old kit and bring my laser to life!
Step 1Safety, Tools and More!
This is the step where I tell you to be safe. Lasers are dangerous and if you aren't aware they can cause damage to your vision if used improperly. So please don't look at the laser. You've been warned.
Second, the power supply can be dangerous if you use it without the laser connected. Make sure you are careful with the power, you may get hurt. Or shocked. Anyway, pay attention.
If you're going to make one of these you'll need these tools to begin:
  • Soldering Iron
  • Solder
  • Damp Sponge
  • Safety glasses
  • Needle nose pliers
  • Wire Cutters
If you want to learn more about lasers then I'd check out Wikipedia: http://en.wikipedia.org/wiki/Laser
Attached are the original instructions and a scan of the educational pamphlet I filled out as a kid. Even though Elenco discontinued this kit in the late 90s I still want to point out that this is their kit and their material. I've included it here in good faith and as documentation for others that may find their own kit hiding after 20 years and want to build it:) Don't be a jerk and try to pass it off as your own stuff. That's my disclaimer.
45 comments
1-40 of 45next »
Nov 10, 2011. 8:13 AMDream Dragon says:
A really nice story and a well documented project in case anyone happens to have one of those things knocking around. Even if it's been assembled, this instructable might give clues to how to repair and replace parts.
Apr 20, 2012. 1:02 AMmazda4952 says:
what type of transformers are used?
i cant seem to find the right ones and none of the shematics show any markings.
Apr 6, 2012. 9:42 PMmazda4952 says:
do i need a certain size of laser tube, or can i use any size?
Jan 6, 2012. 2:31 PMLaserRage says:
Awesome story man!
Nov 13, 2011. 4:18 PMXonk61 says:
OK, I read the instructable, and was really pleased to see the details included, Thanks! I've got a box of HeNe tubes and several Hi voltage blocks, all the electronics are encased in epoxy, so as each one quit working, I had no way to repair them. And from this article, I see there's not really that much to one! I can build one, but for a single piece of information I didn't find. What is the voltage input/output of the transformers? (the ratio, I guess is what I'd need to know?)
Thanks so much for posting this!
Nov 18, 2011. 7:47 PMXonk61 says:
I would very much appreciate it! Thanks for the reply
Nov 13, 2011. 7:51 PMOrenLeavitt says:
Nice!
I tinkered with my first HeNe laser tube as a teen in the late 1970's. I still have that tube (it's one like yours but housed in a nice aluminum tube) and another larger one that is 2 feet long.
Thanks for sharing!
Every month I looked forward to receiving Popular Electronics, Radio Electronics, the Edmund Scientific, and other electronics catalogs every month!
Nov 17, 2011. 1:26 AMOrenLeavitt says:
I would love to put this back together sometime and share it - time permitting...
I have been thinking about a revised compact power supply design using a TV fly-back transformer. Thanks to flat-screen technology, there is a glut of surplus CRT fly-back transformers out there for cheap.
My old power supply was simply a small transformer (120 VAC primary/900VAC secondary) coupled to a half-wave voltage multiplier (like the network of diodes and 0.01µF capacitors on yours) to get the open-circuit output voltage up to the several kV needed to start the tube, and a current limit resistor.
Nov 14, 2011. 2:35 AMrkimball4 says:
Great story. I will say though that this is probably out of reach for most. I have used these same tubes for over 30 years in my career field. They are now cost prohibitive as the HeNe tubes are priced over $800. Maybe you can find cheaper but not by much.
Hang on to way you have and enjoy.
Nov 13, 2011. 5:22 PMastrong0 says:
I wish you could shoot the laser around the house like that newer James Bond movie.
Nov 13, 2011. 5:04 PMAce Frahm says:
What is that red triangular tool? Is that for bending leads?
Nov 13, 2011. 3:38 PMvenom1539 says:
LOL, don't look into laser with REMAINING eye.
Nov 13, 2011. 3:13 PMtrike road poet says:
Could NOT download the 'LK1_Study.pdf' Instructable site didn't seem to want to download. Is there a way to get a download???
Outstanding project and one I remember from my own youth. Great piece of work and thanks for the memories!!!
Nov 11, 2011. 9:50 AMdrbill says:
I remember waaaay back in '69' when I got my HeNe Laser Plans from Lindsey Publications. I had to go to a neon sign maker to get the transformer and a 12 inch HeNe tube made. My mom worked for Montclair Electronics so that's where I purchased the dilectric mirrors for $60 buckolas. There were Brewster Windows back then too.
I used little standards to mount the mirrors in casting sand from metal shop.
When the thing was turned on I was blown away when it worked and so were the teachers. Their Laser came from Edmond Scientific.
We spent the next week playing with the focus and measuring beam divergence at different distances.
I know how cool it is to put something, like what you did, together.
Great I'ble keep going with it and put together a holographic table. You should have a lot of fun with your device.
Nov 13, 2011. 2:27 PMbricmic says:
I have a laser like in 1980 which operated until 1990 the pictures of the old laser here: http://micbric.free.fr/laser/
Bye
Nov 13, 2011. 1:45 PMstephenfitton says:
Back in the fifties I was intrigued in lasers, $100,000 from Mr Howard Hughes to Mr Goodman to research lasers,Got a pink ruby light enhanced laser going,Mr Hughes did not patent it for good reason Mr Testler had done it in the thirties and all books relating to it was removed from my local library soon as I mentioned it,
Instead a volumetric book by testler was lodged at my library in scientific language.From the American library of Congress!
Nov 13, 2011. 1:23 PMXTL says:
some of those capcitors must be rated at a very high voltage - please mention which ones.
Nov 13, 2011. 12:53 PMlurkingdevil says:
Amazing, well written and enjoyable instructible. I'd rate this 10/10.
I can see how excited you were to put this together in your instructable.
Nov 8, 2011. 9:55 AMKiteman says:
Oh, that's nice!
How powerful is the finished laser?
(And I'm the only one who thought "Oh, light sabre!" when they saw the close-up of the lasing chamber?)
Nov 8, 2011. 5:09 PMtim127 says:
Is there any way i could get one of those kits or something similar? really cool laser by the way
Nov 14, 2011. 6:41 AMlspicer says:
Follow this link for all you want to know about Lasers. http://community.wickedlasers.com/
Nov 9, 2011. 7:54 AMcaitlinsdad says:
I'll tell ya, these were things of inspiration back in the day. You would go through the edmund scientific catalog to see if you could ever afford one, those machined aluminum mounting rails were cool. If you had one, then you would point it at the moon and see if you could put a spot on there. Of course, you had to dream about getting or building a high enough power telescope to see if it worked. I thought HeNe lasers were in the green range? It is way more fun than taking apart an ordinary laser pointer.
Nov 8, 2011. 7:30 PMfsargent says:
Excellent job! It's so great to see a childhood dream come to "light!" Hahahahaha
1-40 of 45next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
50
Author:natantus(Chris Gilmer Project)
I'm a software and aerospace engineer. When I've got free time I like to work on robot projects and love to play with my Makerbot Cupcake and Eggbot. I would love to be involved in DIY prosthetics a...
more »
