Childs Electric Car
28,598
62
12
Published
Introduction: Childs Electric Car
About: I build therefore I am.
This is another one of those projects where I wish I had taken pictures as I went along. The original plans came from http://www.realifetoys.com/ where they have a selection of parts, plans and information available.
A friend at work made the Land Rover Series 1 in perfect detail for his kids and he had some parts left over. I had them off him and had a look at the plans to see what I could make with them.
You basically use 9mm MDF and cut out the panels, use glue, nails, screws and anything you can get your hands on to stick everything together. Then use body filler and the normal procedure to blend all of the bodywork.
I purchased an old 50cc quad bike and a 4 wheel electric mobility scooter from my favourite haunt eBay :) Then it was a case of remove the electronics from the scooter, strip the quad and cut / weld all of the bits together to fit the new wheel base. To make my life a bit easier I made a ladder frame from some steel U section, fitted the drive gear to that then bolted that to the base of the car. This also stiffened up the chassis.
I used an old vacuum cleaner pipe for the exhaust, and the original seat from the mobility scooter instead of the bench seat that these things have, then I moved the steering wheel and the to the centre as well. All of the electrics including the charging circuitry were transplanted from the mobility scooter and fitted below the seat. The car basically has two peddles, one for forward and one for reverse. I made it so the reverse is only half the speed of forward for safety reasons. To brake you simply take your foot off the peddle and the motor brake does the rest. So in order to move it manually I added a leaver to disengage the motor brake.
Another cautionary thing I did was cover the base with standard car under seal, as my son used to take it over the fields and it would always come back coated in mud. And we all know what happens when MDF and water get together!
I made the back so I could open it and fitted a charging socket in there, to charge it I simply open the door and plug a 230V kettle plug in. under the dash is a variable resistor that controls the maximum speed. This is important because by using the 50cc quad wheels you are increasing the ratio and thus increasing the speed. It also turns out that there is a legal limit of around 6km/h and this “can” do around 15 Mph!
That is quick enough for most kids!
I purchased some trailer lights and fitted some LED’s to a piece of breadboard, then hot glued them together. The car has working indicators, using the original circuitry from the scooter, head lights (more LED’s on a breadboard behind plexi glass) side repeaters, (yet more LED’s in trailer lights) and two Blue cold cathode tubes fitted underneath. A bit of bling for my son!
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    12 Comments
    How much did the baby car cost?
    How much did you pay for plans (CD or print)?
    would you like to sell the plan, as from a second hand?
    Hi,
    sorry for the delay, the plans were from the internet but the parts I used were from a friend who built the proper land rover version, these were just some bits he had left (where he cut them wrong) and I just made it up as I went along.
    it probably cost me around £350 for all the parts, the most expensive being the electric scooter.
    Kind regards
    Hi, the motor was the one from the mobility scooter. It was just a case of removing the rear axle and extending the drive shafts to the correct width.
    I did try a new motor but the drive circuit got a bit warm, I didnt check the loadings before I swapped it out but luckily didnt do any long term damage.
    could you please add a specific parts list please!!
    Hi,
    There isn't a specific list of parts, it all depends on how you want to build one. if you look at the link at the top there you can purchase the plans for various vehicles and they give you guidance on the best ways to get it moving. I have limited resource but still managed to build a solid vehicle. The majority of the info is in the above description but if you need to know anything specific just ask away and I will try and help out.
    Do you have your own parts list because I would like to build one just like yours.
    I don't usually comment on slide shows but this project is just bad to the bone !
    My son and his lifelong friend both have 3yo kids, what started with a store bought powerwheel that needed a new battery, which was replaced with a less expensive trolling motor battery, has turned into an obsession of rescuing, cannibalizing and rebuilding the plastic toys into terror inducing speed machines, ok... 15-20mph... but those kids have a BLAST running thru the woods and mud. I'm sending them this link ... maybe instead of the 6 wheel drive jeep they are considering building from 3 donors they can go this way....
    I heard that when the powerwheels cars first came out, if you reversed all the gears you can double the speed that they give out.
    Thanks!
    I am not a big fan of these pictural ones either, you get all excited but there is never enough information on them.
    However, as this was done back in 2008 I didn't think about documenting each bit. I will try and advise if you have any questions so feel free to ask.
    Kind regards
    Darren
    Thank you!
    I have limited space and limited resources but it turned out good in the end :-)
    Have a go, its fun to build and to drive!
