3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
"Mr. Fire Face" the Outdoor Fireplace Made from old Propane Tank
\"Mr. Fire Face\" the Outdoor Fireplace Made from old Propane Tank
This outdoor fireplace turned out really well, and brings joy to all our friends.
It's a quick project for anyone who has a way to cut metal.
Star and I built it a couple of days ago,
and it's already been the center of some nice fireside gatherings.
The main safety concern is to make sure there's no flammable gas left in the tank when you start brutalizing it.
You can start out with any metal tank, but we used a 20 gallon vertical propane tank.
A few years ago they changed the valves on new propane tanks, and no one wants the old ones anymore. So you can get them for free.
We were going for a SF Burningman aesthetic, but you can make yours any style you want.
Step 1Safely Remove All Traces of Fuel
It's pretty important not to burn yourself to death while making this project.
Here are some hints as to how to avoid that.
Open the valve just a little and see if anything comes out.
If not, proceed.
Tap on the side of the tank with a wrench. Tap up and down on the side. If the sound changes as you go up and down the tank, you could be encountering liquid in the tank.
If not, Proceed.
Lift the tank - is it really heavy? That could be a sign that there's something in it.
If the tank seems light for its size, proceed.
Employ any other means at your disposal to determine if there's anything in the tank.
If you're sure it's empty, proceed.
Drill a very small hole in the top of the tank. Hopefully nothing comes out. You'll probably smell a little bit of propane stink. That stuff is pretty rank. If there's no gas gushing out but you still smell it, that's probably okay. You can expect some traces.
Drill the hole big enough to put in a compressed air nozzle. Not a tight fit, you want it loose so you can flush the old air out around it.
Blow lots of compressed air in until you don't smell that propane stink anymore.
Drill the hole even bigger so you can fill the tank with water. Fill it with water. Now you're sure you've flushed out all the old flammable gas. If you want to be fancy like an Alaskan you can start cutting the chimney hole or fireplace door out while there's still water in the tank.
14 comments
Feb 19, 2012. 10:54 AMMrBillG59 says:
You could also do this with an old dead compressor tank and not have to worry about the flammable gas. You might also get wheels for rolling, free.
Apr 11, 2010. 12:14 AMcarnyboy says:
Totally agree with the first comment. Remove the valve and fill with water to displace any trace remnants of the gas. Saw a propane tank dismantler do it with those old tanks that you can't fill any more. Cheers!
Feb 25, 2010. 7:18 AMDaddybob says:
I just yesterday took a valve out of an old 100 lb. cylinder and was going to junk it. Great save! Truguillotine has given excellent advice about cleaning a tank out before cutting. Having been knocked down by a 1 quart gasoline tank that was full of water while being brazed, I can attest to the danger. Consider this as a final safety precaution before cutting. Wire up a model rocket engine and drop it in the tank, get in a safe place, and fire the rocket engine to be sure no hazard remains.
Jul 17, 2007. 6:50 PMtruguillotine says:
First let me just say that this is an awesome idea and a great way to recycle something old that doesn't have a use anymore. BUT..... I do work at a place that fills and sells gas(Oxygen,Nitrogen,Helium,Acetylene,Propane...ect.) We often have people come in to take old cylinders off our hands and make large bells out of them. Anyway, the way you are supposed to empty out a propane cylinder is to.. 1.Open the valve and bleed out the gas. 2.When there is no more gas exiting the valve, you can just remove the valve. No need to cut any holes just yet and risk blowing yourself up. Just secure the tank and use a wrench to unscrew the valve. 3.If you are going to be doing any cutting on the tank fill it with water for at least a week with water and degreasing detergent (dawn dishsoap works well). 4.Empty the tank and then you should be set to start cutting. The metal inside of propane tanks is porus so it will pit out the cylinder, leaving little bits of untraceable gas. So be safe when cutting and have fun with your creations!
Feb 3, 2010. 11:19 PMspylock says:
Do you know of a site that shows how to make a bell,that sounds like something I might like to do.
Jan 22, 2009. 12:06 PMshocker187 says:
I done a bunch over the years and I reckon the water fill is the best way.Im loving the face on this,git on Tim,you the man
May 16, 2008. 6:17 PMthoraxe says:
would it be possible to make say... charcoal with this? Take out the face, keep the holes at the bottom, and cut the top completely off?
Jul 9, 2007. 1:59 PMIdahoDavid says:
I have done soemthing similar. Small barbecue using an old helium tank like those you get at party store.
May 16, 2008. 6:16 PMthoraxe says:
yes, a helium tank would be much more safe to cut into
Jul 9, 2007. 5:49 PMlemonie says:
Yery nice, but could you add a picture that shows the exhaust port on the top? Looking at it, turning the non-pickaxe legs the other way around might have enabled you to use the wheels for moving this? L L
Jul 14, 2007. 5:50 AMlemonie says:
Oh yes, thanks. The top hole is much smaller than the bottom, and must restrict airflow - does this help to control the rate of burning and heat output? And have you tried cooking/boiling water on the top of this? L
Jul 9, 2007. 5:51 PMKiteman says:
This is very nice. I generally disapprove of patio-heater thingies, since what else are they for but warming the environment? This, however, I like - burn scrap lumber, undergrowth etc, and it has no larger a carbon footprint than leaving the fuel to rot on the ground. It has a sort of mega-hobo-stove ethos. Your next job is, of course, to fit racks inside the top section for cooking / smoking purposes (cut a hatch round the back so that you don't spoil the image).
Jul 10, 2007. 2:38 PMstasterisk says:
Indeed, a grill was placed over the top of the stove!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1249
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
