Chinese paper throwing star
 by Goalie1
This is a simple way to make a chinese throwing star!  You can use different kinds of paper to make your star.  Notebook paper is shrper, but it does not have much weight.  Printer paper I think is a good selection.  It has weight and some sharpness.
Step 1: The Beginning!!!
The first step is to first grab your kind of paper. Either notebook or printer.  Lay it down in front of you so that the paper is like this.
Goalie1 (author) says: Feb 4, 2010. 6:13 PM
This is my first instructable so if you have any tips, I would appereciate it!!
DCengineer in reply to Goalie1Jan 7, 2013. 10:35 AM
It was a good instructable - but you may want to take better pictures of each step because I couldn't always see what you were doing. I was able to work around that and had two made in about 15min.
tankguy in reply to Goalie1Feb 5, 2010. 5:51 AM
 You should try using printer paper, it's a lot stronger. You could also try stapling along the edges to give it weight and make it look cooler.
Goalie1 (author) in reply to tankguyFeb 5, 2010. 9:07 AM
Ok. Thanks!!  Any tips on how to make my insructable instruction more clear?
tankguy in reply to Goalie1Feb 12, 2010. 8:18 AM
 Well, I like to take pictures in sunlight rather than using flash or a lamp or something like that. It just makes the picture look nicer. You can check out my instructable to see what I mean.
Goalie1 (author) in reply to tankguyFeb 13, 2010. 2:44 PM
OK.  Thanks, I'll go look.
DCengineer says: Jan 7, 2013. 10:32 AM
Made some for my little brother and they work great! It helps to use staples to hold them together
soccerqueen says: Nov 28, 2010. 12:00 PM
hi this is an awesome instructable
cloggy01 says: Jul 27, 2010. 5:08 PM
heyy thanks dude im totally using theese in french and maths! :D
007dna says: Apr 30, 2010. 1:40 PM
 I used to make these in school all the time. I stapled the edges, and put little weights as well, and the thing could you half a football field. It was awesome. You should try that.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
