Introduction: Chisel Holder
Picture of Chisel Holder
Step 1: Chisel Holder Piece
Picture of Chisel Holder Piece
Draw the shape of the chisel holder on your piece of metal. The metal has to be at least 3/4 inch thick or it will not hold the chisel like it's designed to.
Step 2: Cutting It Out
Picture of Cutting It Out
Now cut out the shape with a cutting torch. I used a victor acetylene cutting torch with a #1 tip on it to get a good fine cut on the thick metal.
Step 3: Cleaning It Up
Picture of Cleaning It Up
Now use a grinder something very abrasive to get the metal that melted onto the holder off.
Step 4: Drilling
Picture of Drilling
Now drill a hole in the holder part then tap the hole. Make sure you drill the hole smaller than the threaded rod so that once you tap the hole it's a tight fit and the rod won't wiggle.
The second pic shows the angle that the rod should be going in so that it will hold the chisel like it's supposed to. I used a drill press to get the perfect angle like I wanted.
Step 5: Making the Handle
Picture of Making the Handle
I used an old hatchet handle I had laying around for the handle. I drilled a hole in the handle then I tapped the hole so that the rod wouldn't slide out. I put wood glue in the hole to keep the threaded rod from screwing out when I was tightening the rod to hold the Chisel in place. Now let the wood glue dry over night. Then screw the chisel holder part onto the threaded rod with the handle then you have a chose holder.
Step 6: How You Use It
Picture of How You Use It
To use this tool you get your chisel or punch and put it in the holder then screw till it's sucre and won't slide out. Then you hold the handle of the chisel hold and then hit the head of the chisel or punch. The main reason for making this tool is so that you don't hit you finders when you miss the head of your punch our chisel.
rimar2000 (author)2014-06-14
Good idea!
About This Instructable
2,682views
9favorites
License:
More by dirtbike98:Fixing A Cheap AnvilHomemade ClampChisel Holder
Add instructable to:
