3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Chispito Wind Generator
Step 4HUB AND MOUNT
HUB AND MOUNT
Cutting Tail
The exact dimensions of the tail are not important. You want about one square foot of lightweight material, preferably metal. You can make the tail any shape you want, so long as the end result is stiff rather than floppy.
Drilling Holes in Square Tubing - using the 5/16" drill bit
1. Place the motor on the front end of the square tubing, so that the hub part hangs over the edge and the bolt holes of the motor face down.
2. Roll the motor back so you can see the bolt holes, and mark their position on the square tubing.
3. Drill a 5/16" hole at each mark all the way through the square tubing.
Floor Flange Holes
This will be dealt with in the assembly section of this manual, as these holes are what determine the balance.
Drilling Holes in Blades - using the 1/4" drill bit
1. Mark two holes at the wide end and along the straight edge of each of the three blades. The first hole should be 3/8 " from the straight edge and 3/8 " from the bottom. The second hole should be 3/8 " from the straight edge and 1 1/4" from the bottom.
2. Drill these 6 holes.
Drilling and Tapping Holes in Hub - using the 7/32" drill bit and 1/4" tap
1. The Treadmill motor comes with the hub attached. To take it off, hold the end of the shaft (which comes through the hub) firmly with pliers, and turn the hub clockwise. This hub unscrews clockwise, which is why the blades turn counter-clockwise.
2. Make a template of the hub on a piece of paper, using a compass and protractor.
3. Mark 3 holes, each of which is 2 3/8" from the center of the circle and equidistant from each other.
4. Place this template over the hub and punch a starter hole through the paper and onto the hub at each hole.
5. Drill these holes with the 7/32" drill bit.
6. Tap the holes with the 1/4" x 20 tap.
7. Bolt the blades onto the hub using the 1/4" bolts. At this point, the outer holes have not been drilled.
8. Measure the distance between the straight edge of the tips of each blade. Adjust them so that they are all equidistant. Mark and punch each hole on the hub through the empty hole in each blade.
9. Label the blades and hub so that you can match which blade goes where at a later stage.
10. Remove the blades and then drill and tap these outer three holes.
Making a Protective Sleeve for the Motor
1. Draw two straight lines, about 3/4" apart, along the length of the 3" x 11" PVC Pipe. Cut along these lines.
2. Make a 45 degree cut at the end of the pipe.
3. Place needle nose pliers inside the strip that has been cut out, and pry the pipe apart.
4. Making sure the bolt holes of the motor are centered in the middle of the missing strip of PVC pipe, push the motor into the pipe. An extra person will make this a lot easier.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
58
Author:velacreations
