Chocolate Mousse
56,540
138
57
Posted in FoodDessert
Introduction: Chocolate Mousse
Chocolate Mousse is a delicious, chocolaty, and creamy dessert that goes with almost any occasion. My family and I have had success with mousse as a dessert at birthdays, holidays, and almost any other family gathering you can think of. It is very creamy with a few bits of chocolate to add some texture. This particular instructable follows my aunt's recipe, which allows for a mousse that is slightly sweeter, more rich, and, in my opinion, a better dessert than that which you can find in some restaurants.
It is fairly easy and quick to make, but to get the best results it needs to be chilled for about two hours.
Contains chocolate and dairy products.
Step 1: Gather Ingredients
Gather your ingredients.
-Approximately 9 ounces of dark or semi-sweet chocolate
-Four large eggs
-1/2 pint of heavy whipping cream (one cup)
-One cup of baker's sugar (regular sugar will work; more or less to taste)
You will also need four medium or large bowls and a mixing utensil (preferably flexible in order to scoop up the most chocolaty goodness possible).
Step 2: Separate Eggs
Separate the eggs into two bowls. Put the whites in one bowl and set aside for later. Put the yolks in another bowl. We will be using the yolks in the next step.
Separate the whites from the yolks by splitting the egg in half and carefully sliding the yolk from one half to the other so that the whites will fall into the bowl but the yolk will stay in the egg.
Step 3: Add Sugar to the Yolks
Just as the title implies, add one cup of sugar to the yolks and beat until the yolks are very light. The new mixture should be an off-white or cream color.
While you are beating the yolks, you should put the chocolate into the microwave for two and a half to three minutes at 40% power. Stir the chocolate until it is smooth and allow it to cool while you continue beating the yolks.
Step 4: Add the Chocolate
Add the chocolate to the egg yolks and fold until it is well mixed.
After you have mixed the chocolate and egg yolks, you should start beating the egg whites.
Step 5: Add the Whites to the Chocolate Mixture
The egg whites should be beaten until very stiff.
Once the egg whites are stiff, they should be folded into the chocolate mixture.
After you have thoroughly mixed the whites into the chocolate mixture, you can start beating the whipping cream.
Step 6: Add the Whipping Cream to the Chocolate Mixture
When you are finished beating the whipping cream, it should be stiff; even more stiff than the egg whites were.
Fold the whipped cream into the chocolate mixture.
Step 7: Chill
After you have folded the whipped cream into the chocolate mixture, you should let it cool in the fridge for about two hours.
You could eat the mousse now, but if you let it chill first it will stiffen and the bits of chocolate will harden and provide a better texture.
You can add flavors, such as a teaspoon of instant coffee or some white chocolate, to add some variety to your dessert.
    • Slow Cooker Challenge
    • Spotless Contest
      Spotless Contest
    57 Comments
    Wow a lot more complicated than my pudding+whipped cream!
    @grajasekhar: I suggest you try using a metal bowl to beat the eggs firstly (either steel or copper as you suggested), and then try this trick - put the bowl in an ice bath and beat the egg whites, they should stiffen up into lovely peaks for you. An ice bath is exactly what it implies, on the off chance you did not know, along the same lines as a double boiler, but minus the heat & add ice. Basically fill a larger bowl 3/4 of the way with ice, place the metal bowl you're beating the eggs in the bowl of ice and have at it... ?
    I have found that the temperature & humidity in a home make a difference as to how long it takes to make the eggs into soft peak stage. I've made it in winter & summer-time and have had different results each time ( until I figured out this trick, since then, no problems). I lived in Houston the last time I made this though, roughly 4 years ago. Live in Princeton, NJ now. I need to get back to making it again! In Madras isn't the weather quite hot and balmy most of the year?
    If you add lemon it will change the taste, I would think, but a tiny pinch of salt always brings out the flavour of chocolate, and is always recommended by the best professional chefs while making anything using chocolate. By tiny I mean really TINY though. A heavy hand will ruin it for you.
    Enjoy & I hope it works.
    if I am understanding this correctly, it uses raw egg whites...isn't that generally considered a nono? Raw eggs, I mean.
    It used to be, but now, with modern health care and whatnot, the chances of catching salmonella from a raw egg is about 1 in 20,000. Even if you do get salmonella, most people usually get better on their own in 4-7 days. I have had this dessert at least 30 times in my life, and the only time I got sick was when I ate too much.
    To limit or lessen the chance of getting a food-borne illness from the eggs: Wash the eggshells before cracking them, and when separating the eggs, don't toss the yolk back and forth between the shells, as this increases the chance of the eggs picking up the salmonella bacteria from the shell. As well, the very young and very old should probably not eat this dessert. Oh well, more for us! :)
    I've made this mousse a few times now and it is always a HUGE hit. For my ladies' groups, it serves closer to 20, but that's at a party where we all bring food to share. I take it in a big glass bowl with little cups and spoons to serve it. It's worth any risk of eating raw eggs, in my opinion. :)
    Hi, I'm from India. 1. I tried making this but the problem began when I was beating the egg whites. They wouldn't become stiff no matter what I did. The only thing that would form is more and more foam but it was still pretty watery. Tried an egg beater too, like the one in the picture included in this post. But to no avail, still wouldn't thicken the way you've shown in the picture. Please help me find out what I'm doing wrong and how I should do it. :/ 2. Heavy Whipping cream (or whipping cream or whipped cream) is something that no matter how much I've tried, I've not been able to find. No one stocks it. I've been using fresh cream which again doesn't stiffen when beaten. Any suggestions / substitutes?? 3. The way I've made it, it was a bit more fluid at the end, so I melted some gelatin (a very small amount) and added it after cooling the gelatin. However the gelatin doesn't seem to be mixing with the chocolate mixture well. It just seems to be clumping together in one place. Still, I just put it in the fridge and I'll take a look at it after two hours. Do you think I've messed the whole thing up big time? :(( Thanks in advance, I'm just beginning to cook.
    1. The egg beater you are using is hand-powered, yes? That may be the problem with the eggs. It takes a long time to beat the eggs- even with an electric egg beater. It may be that you just didn't beat them long enough (though I don't know how long you actually did beat them) or it may be that you need an electric one to be able to beat the eggs fast enough.
    2. After a quick search on Google, I couldn't really find any substitutes to heavy whipping cream- other than using light whipping cream or just whipping cream. I don't know what you could try to substitute it with, but it sounds like you couldn't find any sort of whipped cream or whipping cream. I don't know if regular cream will work, but it usually takes a long time to beat the cream to get it too thicken enough.
    3. I don't know how to really help with the fluid- I've never had a batch that has had fluid in it. It may still taste fine with the fluid, but I don't know.
    Thank you for replying so quickly. Yes the egg beater was hand powered. I was whipping the eggs for around 15 minutes. What I found on googling the egg white beating thing was that adding a pinch of salt and a few drops of lemon juice, as well as using a copper vessel would help get the kind of white peaks that you've described. I'll try that next time around. And I couldn't find any sort of whipping cream, as you said. It actually tasted pretty good. Albeit it was a bit more creamy than a usual mousse should be (as in slightly less solid and more semi solid), but that would probably be because i couldn't find any whipping cream to give it the proper texture. Thank you for the great recipe.
    Glad you liked it! Tell me how it turns out next time with the salt, lemon and copper with the egg whites.
    Can you please tell me how many servings this makes?
    Probably somewhere between 10 and 15, depending on how much people eat. It's pretty rich, so I don't suspect people will eat too much of it.
    The Hello, egg whites won't whip if there is ANY fat on your utensils.  So, wash your beaters very well and don't use a plastic bowl as it can't be 'de-fatted' well enough.  Also, there are some that think freshly laid eggs don't whip well.
    That's all it takes. Good luck!
    no.
    ive used a hand wisk, and the foam is what you want.
    Depending on how big of a serving (it's really rich so people don't take too much sometimes), I think it has about 10 servings.
    *takes notes feverishly*
    Yummmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm.................................................................... I love it yummy!!!!!!!!!!!!!!!!!!!!!!!
    do you mean the whites?? this is confusing...
