loading
loading
Chocolate Nut Assortment
FeaturedContest WinnerContest Winner
Picture of Chocolate Nut Assortment
Chocolate hearts aren't for everybody...
Step 1: Form Mold
Picture of Form Mold
Make Wooden Frame
Cut two 3.5" wood strips
Cut two 5" wood strips
tape all pieces together.  Tape the last corner with a tab of duct tape to use as a clasp (you will need to attach and remove it for each batch)
Silicone Putty Set Up
Measure out equal parts of silicone putty components and mix according to instructions
Spread out evenly in the frame
Place hex nuts
Wait 10 minutes
Cut Mold
Remove nuts from mold.  This can be tricky since you will have to unscrew them off the silicone.
Cut each section in half.  Trying to unscrew less-than-solid pieces can result in accidental cracking.
To make filled chocolate, cut out middle piece of silicone and sand to even out both sides.
Variation
I also made a smaller mold with different size nuts...and a wing nut : )
Step 2: Chocolate Shells
Picture of Chocolate Shells
Once the mold is all set, it is time to fill it!
Melt chocolate over stove or in the microwave and stir until smooth.  I used a small pitcher so that the chocolate could be poured directly from it.  I added a silicone sleeve to the side in lieu of an oven mitt.
Pour into molds.
For the molds that will have filling, pour in enough to cover the bottom and use a spoon to push chocolate against the sides of each section.
Sections for the solid sections should be filled in 3/4 of the way.
Tap mold against the table to push air bubbles up and ensure that chocolate spreads out evenly.
Place mold in the freezer for 5 minutes.
Step 3: Solid Chocolates
Picture of Solid Chocolates
A few variations for solid chocolates.  Try stirring in...
  • Dark and white chocolate together
  • Chopped pistachios
  • Coconut flakes
  • Drizzle with contrasting chocolate
1-40 of 48Next »
mrbrian19694 years ago
?nutella? the only place i've seen that is in the dominican republic. are you from the D.R.?
here in aussie they try and convince you nutella is GOOD for you..HA...
hey why not? yeah I see it in a bunch of recipes now, I wonder why I never saw it before?
yea, its like i never noticed how much i need corn syrup....maybe i better make an Ible on how to make it....
we have it here in canada...
try walmart
I think it would have been cool if you had made a Sugar Toolbox...making an even better gift.
RamDragon3 years ago
I didn't see the question, but was there a food-safe consideration with your mold choice? Brilliant intructable, by the way. Perfect for mending a broken heart.
annahowardshaw (author)  RamDragon3 years ago
Don't worry, the silicone is food grade.
sunshiine3 years ago
This is soooo kewl! Nice ! Thanks for all your hard work.
Now someone needs to make other chocolate parts, ie. screwdrivers, wrenches, pliers, etc!!
annahowardshaw (author)  javajunkie19764 years ago
And chocolate wood to build with! Cherry flavored cherry...walnut with walnuts : )
...ironwood - Ouch!
Oooh, best answer EVER!!! Pecan with pecans... *giggles*
annahowardshaw (author)  mslaynie4 years ago
Nice one!
Ash would be gross. Bloodwood would be terrifying!
Ewww, ash would be really gross, I won't even THINK of bloodwood! *hides in the corner*
Dogwood...kinda illegal haha
Dr. dB4 years ago
...not entirely sure, but you probably have a screw loose to have though-up such a deliciously-nutty project...
the pun is undenyable! I MUST make these! :P
...pundeniable...?
Hey, would chocolate bolts work? I just thought of that since my screen name is "nutsandbolts" and I saw this on my email so why not bolts?
A "fitting" variant on the theme, perhaps with dried-fruit-slice flat-washers?
...and you'll have to decide whether to go SAE or metric...?
SWV17874 years ago
Does it come with a warning label?
Dang, that should be my profile image.
instructables in general should have this warning label ;p :)
boocat SWV17874 years ago
You are so funny!! :P
Lindie4 years ago
Fun idea!
mary candy4 years ago
OMG
I want to eat it all !
big-jamie4 years ago
gonna make these for my girlfriend as she loves chocolate but hates nuts and im such a good boyfriend i'll make her chocolate nuts ;) thank you for this instructable, brilliant idea.
you're great! if my bf did that, i'd laugh my soxs off!
annahowardshaw (author)  big-jamie4 years ago
That's one lucky lady...
Logicsama4 years ago
hahahaaaaa this is so awesome I'm gonna make this for sure...
If you made chocolate bolts, would the nuts be able to screw onto them?
annahowardshaw (author)  ScottyAlmanjoy4 years ago
I'm sure they would since they needed to be unscrewed off the mold and did retain the threads. But I'll have to pick up a big bolt and try it!
If anyone beats me to it (or molds some other hardware) please post a picture!
Maybe we could start a very specific candy store : )
canida4 years ago
This is utterly brilliant! I love them.
SeamusDubh4 years ago
One way to deal with the threading issue it to make the area of the mold smooth and use a tap to cut the threads like you would in metal.
annahowardshaw (author)  SeamusDubh4 years ago
Great suggestion! I was debating whether or not to remove the threads. It’s funnier to me to have them, but if one were to make these in large quantities, smoothing out the center would make it go more quickly and eliminate the need to cut the molds in half.
No way! The reason I clicked on this instructable was because I saw the threads and wondered if there were actual nuts dipped in chocolate. The threads are an amazing detail that sends this instructable over the top! Congratulations!
NachoMahma4 years ago
. Excellent!
rusty01014 years ago
A chocolate Anvil for the ACME fans.
1-40 of 48Next »
