It depends on a few things:
1) How much money are you willing to spend per use and on equipment?
2) How often will you be wearing this costume?
3) What percentage of skin are you covering?
4) How much time do you usually have to prepare?
5) Do you have to drive somewhere painted up, or can you do it at your location?
6) How long do you expect to be this color?
7) What other difficulties will you experience with colors/brands?
I will try to answer each of these questions for each type of skin covering product. Additionally, if you have Photoshop, you can tidy up professional or even snapshots pretty easily. If you don't have Photoshop, please don't download it illegally, and don't ask me where you can do so - I will not help you do this.
Remove these ads by
Signing UpStep 1Tools and equipment
Suggested tools, at minimum:
Small baggie of wedges, 10 or so
Spirit gum
Spirit gum remover
Black mascara and eye liner, neutral lip gloss
Black pencil and shadow
A set of around 15 brushes include a wide eyebrow brush, a kabuki brush, brow brush and wide and narrow flat brushes
Spare eye shadow applicators and lip brushes
Hair pins and ties
Cold cream and/or facial wipes
False lash sets
Stippling sponge
Spare bottle of contact solution and contacts case
Small tube of concealer
Primer
Small bowl with airtight lid, for mixing
Travel-size Q-tips case
White pencil and white shadow
If painting your feet, legs or other large portion of your body, put towels on the floor, toilet and sink. If your'e in a hotel, call for extra towels - the hotel staff like cleaning make up less than taking extra blue tinted towels from your room.
Something I cannot say enough is: do not buy cheapo make up when buying colors for costuming. Feel free to pick up cheapo stuff for color tests, but don't use only them. I try to buy makeup made in the US, and that is cruelty-free. Try to buy unscented makeup when possible. You won't use your shadow brushes as often as your regular makeup, so make sure you dispose of them once a year and replace with fresh ones, even if you haven't run out of a particular color. Your brushes can become bacteria nesting grounds, so treat them well and keep them clean between uses.
Now I do have to use makeup remover to get it off- it does laugh at traditional soap and water- but I've found that those cloths with makeup remover impregnated into the fabric are a godsend when one is exhausted at the end of the day.
Now the rubies and the halloween store variety are well a joke- and I would never use them. If that is your only experience with grease based no wonder you despise them. 'cause I'm right there with you.
In "Wizard of Oz" the actor who played Tin Man died shortly after filming because of inhaling the dust that made his skin silver. Notice I said "dust", it was not a paint.
http://www.snopes.com/movies/films/goldfinger.asp
As far as I know, there is no truth to the idea that skin will take in oxygen-but if you put things on your skin that are not certified for cosmetic use, most people will have problems.. For example, you should never use water colors or kid's paints for painting skin.
The main reason I mentioned it on the latex paint was that if you sweat, there's no where for the sweat to go except to lie against the skin, either trapped under the latex or damaging the latex. You definitively will not die (from lack of oxygen) if you can still breathe through the mouth and nose. Sweat kept against the skin will not really damage it either, but I wouldn't want to try it.
I'm curious about the type of 'gold paint' used in the bond movie - She probably died of toxic poisoning rather than her skin pores sealing shut.
FluffyDragon did a pretty good job of explaining the pros and cons of each paint / makeup. I have done some haunted mazes and worn latex prosthetics, etc. and they do get warm even when your outside in 40 deg F weather. Latex doesn't breath at all, but if you don't have it completely covering your body you should be fine.
My personal favorites are cream-based makeups and airbrused accrylic paint. I have sensitive skin, but haven't ever had much of a problem with these as the cream I can put on as light as I want and it comes off with water. The accrylic paint also just comes off with water, but if you ever wipe at it it will flake off. That's why you never wipe, always pat.
Just my two cents.
Great instructable very detailed.
Snazaroo is GREAT for full-face application. It's water-based, and behaves similarly to regular make-up. It's hypoallergenic and washes off with soap and water like a dream. (It's also not very expensive; you can buy it at many craft stores. Good for beginners and pros!)
Tribal Ink is alcohol-based for spray-ons...I agree that you should only get into those if you or someone you know is experienced with airbrushing. The investment is NOT cheap. However, I did a few (close to) full body applications and the results were great, and my customers loved how LONG everything lasted. The less oily your skin, the longer the paints last.
Anyway, my two cents. :)
I plan to experiment with it myself at some point, but I just haven't yet.
Snazaroo:
Pros:
- great color selection; mattes, pearls etc.
- a little goes a long way;
- water-based; washes off easily
- solid cakes; nothing to spill
- hypoallergenic, very gentle on skin
- can be used in an airbrush if you have one!
- works well with others; I used Snazaroo with other materials (glitter, latex glue, glitter gel, regular make-up etc) with great success
- website is FULL of painting tips and tricks
Cons:
- some colors don't show up well on light skin
- doesn't stand up to sweat and oil
- reds tend to stain skin (red was the only color I found this problem with)
- batches may vary; some times I had GREAT results with a color, then re-ordered and it was just ok
- website stuck in the 1990s ;)
Hope that helps!
