Introduction: Chopstick Bird Feeder
Step 1: What You Need
Time to get some stuff!
Supplies:
- Chopsticks
- Glue. I'm using Loctite Stik'n Seal here
Toosl (not pictured):
- Dremel or saw
- Q-tips
Supplies:
- Chopsticks
- Dremel or saw
- Q-tips
Step 2: Gluing in Pairs
Round chopsticks are tough to deal with since they roll around so easily so my first step was to glue them together in pairs. To do this as cleanly as possible I used this technique:
- Run a bead of glue down the middle of the pair
- Roll them inwards so the glue gets between the two chopsticks
- Use a q-tip to wipe off the excess glue
Step 3: Glue Together Sections
Here I glued together 4 sections.
Section A (left side) - Two sets of 20 chopsticks each. I kept these separate at first to create a pitched roof, but ended up joining them later for a flat roof.
Section B (top right) - 4 chopsticks for the bottom of the trough
Section C (right side) - Two sets of 6 chopsticks each for the sides of the trough
Step 4: Finish the Roof
Originally the roof was going to have two sloped pieces, but I needed it to be sturdier and so a flat roof with supports would be better. Just glue in four chopsticks and you're good to go.
Step 5: Trough
I chopped off about 1/2" off of the ends of the Section C pieces and glued them to the Section B piece to form a trough
Step 6: Add Supports
I used 4 pairs of chopsticks as supports to come up from the trough. After gluing them in, I used a Dremel to chop them off at an angle at the 5" mark.
Step 7: Add the Roof and Rests
Glue the supports to the roof to provide some shade and bring most of it together.
Now we just need a place for the birds to sit. Add a couple pair to extend out from the trough and a couple more pair to connect those and make a place to sit.
And there you have it! A comfy feeder for the birds. Just hang it, add some seeds, and you're done!
