[Chopstick] Paper Guitar Pick
Published
Introduction: [Chopstick] Paper Guitar Pick
This is a very simple method of folding the paper wrappers of chopsticks (or paper cut into similar dimensions) into a makeshift guitar pick. All that is required is:
Disposable chopstick wrapper/paper in same dimensions (~8-3/4" x 1-1/8")
Step 1: Find You Wrapper/cut Your Paper
Again, ~8-3/4" x 1-1/8"
Step 2: Start Folding
The general shape in the end will be an equilateral triangle, so make the folds as nearly 60 degrees as you can. Make sure that the "tails" of the paper remain about the same length, as well.
Step 3: Keep Folding Around the Triangle
Just follow the edges of the triangle when folding, keeping the layers tight together so the pick will stay sturdy for longer.
Step 4: Tear Off the Access
Once you get down to the ends of the "tails", the end will fold into a little pocket made by the previous folds. To make it a more comfortable fit, tear off part of the paper following the other "tail" edge as a guide.
Step 5: Fold the Ripped Edge Into the Other Folds
Step 6: Finishing Up Folding
If you left one "tail" slightly unfolded like I did, just finish the folding like on the other "tail".
Step 7: Rip and Fold Again
Just like previously, the end is ripped for an easier fit, and folded into the previous folds.
Step 8: The Finished Pick
If you followed these poorly explained steps correctly, you should have something resembling a pick! Yay! Be aware that mileage on it will depend on the intensity of playing, the type of paper used, and how tight the folds are within it.
    • Clocks Contest
      Clocks Contest
    • Backpack Challenge
      Backpack Challenge
    • Stick It! Contest
      Stick It! Contest
