Introduction: Chopstick Trainer With Only a Rubber Band! (and Chopsticks)
This is a pretty cool trick where you can make a chopstick trainer with only a rubber band and the restaurant chopsticks. I have used it and it helps you pretty well. I also like this because you can make this in only a matter of a few seconds.
Well, hope you like it!
Step 1: First Step: Get You Materials!
All you need for this is:
Chopsticks and a rubber band.
Get these and you are ready for the first step.
*By the way... the chopsticks NEED the wrapper. If it has a plastic wrapper, I can't help you.*
Step 2: Second Step: Open the Chopsticks
Open the paper package and separate the chopsticks if they are joined.
Bonus points: rub the chopsticks together so that they don't have splinters sticking out.
Step 3: Third Step: Start Rolling Up the Paper.
Roll up the wrapper so it is about the size of a pencil.
Bonus points again! If you have tape on you, tape the rolled up piece of paper so that it won't fall apart when you are putting the rubber band on.
Step 4: Fourth Step: Put the Rubber Band On
Wrap the rubber band around the end of the chopsticks and the rolled up paper so that the paper acts as a fulcrum. Put most of the rubber band on the very end so that the chopsticks will stay open, instead of closed.
Step 5: Fifth Step: Adjusting and How to Use!
To adjust this, move the piece of paper up and down the chopsticks until it feels comfortable.
To use, hold the top one just like you were to hold a pencil. Then put your thumb over the two chopsticks. The bottom chopstick should just go under the thumb and over the middle finger.
Thank you so much for reading! hope it is useful and hopefully not confusing.
