Christmas Balls
Published
Introduction: Christmas Balls
About: Hi everyone! I'm a hardcore DIY'er, I've published 11 DIY books, just produced my own TV show called Make Your Mark for PBS/APT, I make YouTube videos every week and I'm buried under a mountain of craft sup...
Turn your favorite holiday image into a fun paper ornament for your tree!
Step 1: See How Easy They Are to Make Here!
Step 2: Stuff You'll Need
Holiday print out on card stock
8” medium gage wire
Ruler
Needle nose pliers
Scissors
2 beads, 2 large sequins
1 drinking straw
Large safety pin or needle
Pin cushion
10” of ribbon
Step 3: Here's How!
1. Trim your print out to 6" x 11" making sure the image falls at the 3" mark
2. Cut 6” x 3/4” wide strips as you see in the photo. You will need 16 strips so save the extra pieces for filler
3. With your safety pin, poke a hole on each end of each strip 1/4” up from the edge and right in the center
4. Poke a hole in the center of the large sequins if you need to
5. Cut the straw to 3"
6. Bend a loop in the end of the wire
7. Add a bead and then a sequin
8. Line your strips in a stack in order
9. Starting at the top of the stack, thread them on the wire FACE DOWN toward the sequin
10. Add the straw
11. Starting from the strip that touches the sequin, thread each strip on the wire one by one
12. Add a sequin, then a bead, clip and bend a loop in the wire. Hand on a ribbon and you're done!
    • Backpack Challenge
      Backpack Challenge
    • Creative Misuse Contest
    • Water Contest
      Water Contest
