Remove these ads by
Signing UpStep 1: Supplies
- 2" PVC pipe (Comes in a 10 foot length from most home improvement stores. I cut
mine into five 2 foot lengths, but you can cut whatever size suits you)
- Chain link fence post cap (2")
- Painter's tape
- Red Paint (Krylon Fusion for plastic)
- White Paint ((Krylon Fusion for plastic)
- Circular Saw or Jig Saw or Dremel tool to cut the PVC pipe
Visit Our Store »
Go Pro Today »
They pretty much stay there by themselves. If you wanted to put them straight up and/or needed to fasten them, I would probably just drill a very small hole in the pipe and tack it to the eve with a small nail. It wouldn't take much to hold it in place.
Also, if you can find it, get smooth pvc like I have for the 2 inch posts. I couldn't find it and had to use the french drain type of pipe (luckily without holes) that has the ridges. The paint doesn't stay on as well. If you decided to make these, treat them with care because the paint does chip off easily.
Mine is also supposed to be a gingerbread house, but it isn't easy to see everything in the photo. Above the lights on the eves, you may have missed the candy canes. These were plastic ones from a dollar store that I drilled holes in and mounted. In between the candy canes are little round "candies" I made out of foam. They are really hard to see because they are a light mint color. I re-painted them red for this year and they really stand out now. These are attached using UGlu (www.uglutape.com).
Good luck and Merry Christmas!
The "snow" or "icing" for my gingerbread garage was made from pink foam board. The larger part around the window was measured carefully so it could be wedged between the shutters. The smaller pieces on top of the shutters had holes drill into them and were place on the loosened screws for the shutters.
The large wreath is also foam board.
