Christmas Fire Starter
Introduction: Christmas Fire Starter
What’s more Christmas than sitting around the fire place, with stockings hung, all the family gathered around, watching the fire burn. Well I will tell you it! Watching your father, down on all fours, struggling to get the #@$%! Fire started. Well here’s one holiday trouble that I have a solution for “The Homemade fire-starter”. Best of all! Most of the supplies are made from what would otherwise be garbage.
This Fire Starter is also an amazing camping/Survival tool, just take out the evergreens and pine cones and add more wood chips and add course saw dust.
Step 1: Find Everything
Gather all the supplies need
Supplies needed
New or old candles
Shredded paper
Dryer Lint or Course saw dust
Evergreens trimmed to 1.5”ish
Pine cones or Spruce cones
Paper muffin holders
Cheap Aluminum foil muffin pan
Old pot
Step 2: Fill It Up
Place paper muffin holders in muffin pan, then fill 1/3 of the each of the holders with dryer lint.
Step 3: Add Some More
Push a pine cone in the center of each fire-starter, then put wood chips around the pine cone.
Step 4: Melt Some Wax
Place Candles in pot, heat pot on stove at medium temperature (carefully, combustible vapors are formed here). keep watch over the melting wax until it is fully melted.
Turn off the stove for now.
Then fill the fire-starter half-way with hot wax (be very careful!).
It was suggested to me that i should have used a double boiler and monitored it with a candy thermometer.
Step 5: Let Stand
Let sit for about 1 minute then carefully push the evergreens into the fire-starter. Place a little of the shredded paper on the top of each one.
Step 6: Fill With Wax
Turn back on the stove, heat back up the wax, and carefully fill each fire-starter with the candle wax.
Step 7: Pop Them Out
Let sit until they are hard, mine took about 2 hours to be completely solid. Next you need to pop them out, do this be pressing firmly on the bottom of the muffin pan. You might bend the pan, this is why we used an aluminum foil one.
Step 8: Let It Burn
Make a fire, Sit back and enjoy the warmth of a job well done.
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    this is a very nice fire starter but, you might get a better result if instead of using wax, you could use pine sap, it will burn for a lot longer
    Great idea, but please please always use a double boiler for melting wax. It's way too easy for it to get hot enough to vaporize and then you have a fuel air kind of explosion inside you kitchen! (Double boiler won't stop this, but makes it easier to regulate temp) Using a candy thermometer to track the melting point of the wax you are using if you can.
    Had one friend lose a house this way: be careful!
    Thanks for the advice, I have updated my instructable accordingly
    Thanks Tom! I don't want to be 'that alarmist guy', but.. :)
