If you can solder a little, you can make LED stars. The stars can be made 6 to 10 cm wide and use a 9 Volt battery as a pedestal.
If you want to easily change batteries, take a look at step 5. The star can be mounted on a 9 Volt battery clip...
No video playing? Have a look at it here...
So get your soldering iron, grab your LEDs, find some batteries and kick off the christmas decorating season.
If you're uncertain about your soldering skills: Start with making the star. It's easy. You can do it. Really. Trust me.
Still in doubt whether you should make the star or not? Here's the one decisive reason you were waiting for:
The first three Makers who post a picture of their self-made star in the comments get a 3 months Pro Membership gift code from me.
An additional one year Pro Membership gift code goes to the maker of the funniest / loveliest / greatest picture that involves a LED star :-)
december 17th: lmijacevic gets the first of three 3 Months Pro Membership codes!
Remove these ads by
Signing UpStep 1: Stuff and tools
- 5 red leds, with a 5mm or 10 mm dome: up to you. The LEDs must be red to shine properly on a 9 Volt battery. I used LEDs with opaque domes as well as clear. Use what you think looks best.
- 9 Volt battery.
- 10 cm of sturdy solid copperwire.
- 1 blinking LED, 5 mm dome, red. I bought this one, it works on anything from 3 to 12 Volts.
- 4 "Low current" LEDs, 5 mm clear dome, red. These are LEDs that light up at very small currents. I bought these.
All parts for the star can easily be ordered at RadioShack, Mouser (if you live in he US), or Farnell or Conrad (Euro's, Aussies, rest of the world).
If you're new to electronics: buy a assortment of LEDs like this one.
Costs:
The star costs about €1,60 / US $2,- if you can get a carbon-zinc battery for under €1,-
A blinking star costs about €2,90
Tools and other stuff needed:
- For a template: 5mm plywood or something similar.
- Soldering iron and solder
- Pliers or pincers
- Polymer clay or a third hand to fix parts for soldering
- Multimeter for debugging
Visit Our Store »
Go Pro Today »
I'm going to make some, but can you tell me how long the Conrad Zinc Carbon batteries typically last on a tree?
Y.
I used old univrsal laptop charger for supplying.
My camera is bad,sorry for that.
Thank's a lot for this :D
Anyway, your 3 month pro-membership is well deserved! Great job, thanks for posting!
My tree: no :-(
Give it a try!
Solder the LED's to that (instead of directly to the battery).
That gives you a way to turn it off, and to replace the battery when discharged.
Thnx!
You just got yourself a 3 month pro-membership :-)
Merry Christmas! *<||;o)>
I do like the template very good idea
Y.
And I'm not sure quite how you might fit one into the tree - you'd probably only want the top 'star' LED flashing, I assume, so you might end up needing resistors...
Personally, I find it almost impossible no to leave a soldering iron on too long, and wouldn't want to overheat a battery, so I'd open up an old 'snap connector' and solder the copper wire to THAT.
I made a video, it's in the intro...
One thing I'm not clear on - why did you go for 'low current' LED's? I've looked again at the EvilMadScientist page, and can't find any such reference. Is it jus to prolong battery life?
So, in theory, the star *shouldn't work* : 4 x 1.8 Volts (low current leds) + 3 Volt (blinking LED) = 10.2 Volts. That's about 1 Volt higher than the 9 Volt available :-s
I decided, against the odds, to give it a try anyway. To have some chance for success, I bought low current LEDs (with the lowest voltage-drop) I could get.
... and, to my surprise, it worked!
I assume it works because all the voltages are, essentially, 'nominal' - that is, the battery can't give exactly 9 volts, so is manufctured to give a little more, and the LED's can be overdriven by an amount before you shorten their lives considerably - and everything just happens to match up...
