Having made some of these earlier, I decided to add a few more for the Christmas season. These light boxes, or signs are easy to make, very low cost (the only thing I have to buy is the lights). Lights used are mini-incandescent lamps that are low watt, low heat regular Christmas lights. If purchased at the end of the season, strings can be had for as low as $1.00 each! No "wiring" is required, just use the lamp strings as purchased. Be aware, that these lights should not be left on unattended.
Step 1First Cut Acrylic or Glass For The Front of the Sign
I have a lot of picture frame acrylic and glass that is no longer used for pictures, so I use this instead of buying some new material. To cut acrylic, a special tool is available, but can be cut by scoring with a craft knife or box cutter and snapping on the line. For glass, a glass cutter is needed.
I plan on doing "White Christmas".
Its in your font folder
Search "Fonts"
I can't seem to find a reliable source to download.
Downloaded a program to install it for me.
I'm so doing this for my mom!!!
Means a lot coming from you.
