iImage Information
Having made some of these earlier, I decided to add a few more for the Christmas season. These light boxes, or signs are easy to make, very low cost (the only thing I have to buy is the lights). Lights used are mini-incandescent lamps that are low watt, low heat regular Christmas lights. If purchased at the end of the season, strings can be had for as low as $1.00 each! No "wiring" is required, just use the lamp strings as purchased. Be aware, that these lights should not be left on unattended.
Step 1First Cut Acrylic or Glass For The Front of the Sign
iImage Information
I have a lot of picture frame acrylic and glass that is no longer used for pictures, so I use this instead of buying some new material. To cut acrylic, a special tool is available, but can be cut by scoring with a craft knife or box cutter and snapping on the line. For glass, a glass cutter is needed.
I plan on doing "White Christmas".
Its in your font folder
Search "Fonts"
I can't seem to find a reliable source to download.
Downloaded a program to install it for me.
I'm so doing this for my mom!!!
Means a lot coming from you.
